Also interested in one.
I’m interested in red and deep red.
Add 1 for me please
Cheers
One more for me plz, total of 2
This is an acceptable trade-off for me. It would make it appear approximately half as bright, which is noticeable, but this was never meant to be a powerful red flooder, just a dedicated red flashlight for use in low light conditions.
Perhaps offering the option of XP-E2 Red and XP-E2 Photo Red would be easier for Sofirn? Unlike XP-G3, these 2 emitters seem to be very similar. No additional effort may be needed to offer both as an option, it would probably be a straightforward emitter swap.
I’m also interested in 2.
Thanks!
84 pcs accounted for already.
Only 116 pcs left to make it happen.
When … ok, if Sofirn decides to go for deep red, I’ll take 2. Just saying!
In for one piece of each LED version.
Put me down for 1 more please
Cześć 1stein, just to be sure...I count this as 2 pcs as long as we don't know what LED we get? :-)
Pozdrawiam, Thomas
Cześć, you are so language gifted. Chapeau Bas! Yes, count me for 2 in this case, thank you.
Pozdrawiam serdecznie
Interested.
interested in one
I'm afraid that XP-E2 photo red (I guess it's being called "deep red", too now) could look too dim/too dark as the output is less than XP-G3 deep red. …
First of all, XP-G3 deep red is also called photo red.
According to XP-G3 and XP-E2 datasheets the actual XP-G3 versus XP-E2 radiant flux difference is very small. Just for example right now Arrow has XPGDPR-L1-0000-00F01 (XP-G3 radiant flux code 32, 500mW @ 350mA and 25°C) and XPEBPR-L1-0000-00D01 (XP-E2 radiant flux code 30, 450mW @ 350mA and 25°C).
XP-E2 is the safe bet in this case, imho.
Gracias Barkuti :BEER: I'll keep that in mind when talking to Sofirn again. I ask them to concentrate on XP-E2 deep red only when testing alternatives to XP-E2 red 625nm. OP will be updated accordingly.
Interested.
84 pcs accounted for already. :+1:
Has Sofirn confirmed that with an interest list of 200 they will produce a run?
Hey Lux-Perpetua love this idea, thanks for another custom BLF project. Please up me to 3 in total, maybe more later.
These would make awesome stocking fillers but it’s unlikely the timing will work out.
Nevertheless, good things come to those who wait!
Lux-Perpetua be sure to tell Sofirn to avoid being tight fisted when purchasing the photo red emitters, i.e. to preferably get a high flux bin XP-E2 since the bulk per unit cost differente will be very small.
BLF user koef3 and user Köf3 in TLF tested an XP-E photo red ≈3 years ago. Worth taking a look.
Also, since the C01S driver is rated for ≈1W the driving current for the XP-E2 photo red could be slightly raised without exceeding the maximum rated power. To 450 or 500mA, a current sense resistor swap is all it takes:
Photograph of the stock driver courtesy of djozz. ;-)
Presuming 350mA stock driving current swapping the R27 by an R20 means the current goes up to ≈472.5mA, which is compensated by the photo red emitter's low Vf. This would help making the torch brighter at ≈600mW raw output (close to 25 raw emitter lumens). All in all, it could surpass 20 OTF lumens in high. O:)
