Modded my FF E01 today. LH351D W6 swap and changed the pairs of pink/green led’s on the aux board to 4x red led’s.
Its became one of my favorite lights but sucked down batteries so quickly with the power hunger sst-40, plus while I didn’t mind the tint cri seemed especially low. Lux is up to 72kcd, the tint / cri is much more pleasing and it takes way longer to throttle back now and the beam, which is what made it one of my most used lights is still just as usable, albeit with a bit smaller and more well defined hot spot.
Here’s a family photo, not all of my anduril lights, just those with forward facing AUX leds
I made some long overdue changes to my modding area. It has moved from taking up about 1/3 of the kitchen table to this adjustable height sit/stand desk! Still a lot of cleanup and organizing to do but it’s much nicer already than what I had.
Update! cell phone tested (lux meter app) with a charged & rested EBL 14500,
15kcd startup & 13.9kcd at 30 seconds. 1.5amps at the tail, measured via thick cables and fluke dmm
I think you might be confusing the model names, there’s no D25D that i’m aware of?
My pre-2015 D25A has a removable bezel, just unscrews to give access to the reflector and then the MCPCB. Bit tight in there for a soldering iron though so make sure you have patience and a thin soldering tip when you come to do it. (Learnt that the hard way :D)
That’s for the Alu version though, i believe the Ti is a one piece head. Jon_slider, maybe this is what you’re thinking of?
