Doubling the strength of the spray made sense to me at first too. Except then it only takes 4 coats to achieve 1/2 -green, and that’s kind of insane and dangerous considering these lights already run at or near their thermal capacity on turbo. Plus, what I call “1-coat” is a rather thin layer, and I know less experienced painters tend to make their coats much thicker than me. And man, you can really puddle it on if your lens is laying flat.
I like negative Duv but not at 20-30% reduction in output. I also prefer less range of shift from low to turbo. If you apply a filter on SST20 for example turbo will probably be too rosy and low outputs fine
Would this paintable coating be waterproof?
And more importantly, would it be removable if one decides to swap out the LED, or over coated and made it too pink?
I use Lee filters on many of my lights, but recently have been converting my multi LED lights to have mixed tints. This way, the DUV get’s lowered without needing to use a filter and lower the luminous efficiency.
The idea of paintable coating sounds like a great DIY solution over Lee Filters.
I’d check out a link if you got it.
They are vary comparable in my testing. But the 219b r9080 was dimmer, had a slightly lower CRI, and is of course discontinued so they are harder to get.
imho the only right way to use a filter is minimally. If you get above 1/4 -green that is just an abuse of the tech and doesn’t make sense. At high correction levels like 1/2 -green, the only right thing to do is buy a different emitter that’s closer to what you need.
With more current the output scales differently for each LED, 3A is far from turbo and I think the SST-20’s additional headroom will probably equal it or climb ahead at higher currents.
Just want to respond to this post real quick. IMHO, depending on how many applications you’d get per can, I’d think $15 - $20 per can might be a very reasonable price to some BLF’ers. The “average” BLF’er wouldn’t care much about a little bit of green tint anyway.
Like you say, it’s a matter of how many people care about their green tint enough to spend $15-20 to fix it.
As far as how many applications, it would be a lifetime supply for flashlights. It’s a full size can, so you could probably apply it to the windows on your car or house
The SST-20 is a much newer LED, and it’s to be expected that the tint bins available with good brightness bins will take quite a bit of time to actually get.
See, that’s why I think it would be a great deal for some members. Perhaps you haven’t seen the literally hundreds of lights some members have in their collection. If one could buy any flashlight that looked good to them, without having to even consider the green content of the output, it would be a boon to a lot of them. For some flashlights, there simply isn’t an emitter option that is ‘suitable’ for some people. This spray would represent a significant cost savings in both time and money compared to doing emitter swaps when green tint is the only reason for the swap.
I think this idea held up to debate quite well. So let’s start an interest list. How many flashlight enthusiasts want a can of this Green Delete? It will be $15 for an 11 oz can. Which is not bad at all considering this is a specialty paint. And one can is basically a lifetime supply.
Wow. Nice work Joshk. Very rosy tints are nice but I’m good with simple no green tint. I have a few lights that are just a little bit greenish for me and don’t want to put my remaining lee minus green on them. I’d definitely be interested in this paint of yours.
Some CTO or Amber paint to lower CCT might also be useful. I think these would be nice for diffusers for candlelight effect without sacrificing your favorite normal use CCT. Not sure if regular orange paint can achieve this without sacrificing CRI.
Thanks
Yea a CTO filter paint might be useful for painting a lantern-like dome for a night time attachment. Or just eliminating blue light in general.
If anyone is interested in seeing that happen, drop a comment.
I have SST-20 lights with FA3, FD2, FB4, 5000K, and one with a mixture of four different CCTs.
The light I tested with half-minus-green was FA3, so it was the best available SST-20 tint. FA1 would be better, but I don’t think anyone has managed to obtain those yet.
FA3 with half-minus-green looks pretty good on a white wall, and mostly okay during use, but I have to bump it up a step higher than other lights to get the same brightness. Also, it has some really weird effects on shades of pink and purple. It tends to make pink look more salmon-colored, and makes purple look less vibrant somehow, even compared to other 4000K LEDs.
The effect is strange. It seems to affect different colors in different ways. It’s most noticeable on items like this pink sheet:
The images are straight from the camera, and each one was white-balanced to the center of the beam on the white background before each shot. It’s a pretty good representation of how things look after one’s eyes have had time to fully adjust to each light.
The weird appearance of pink and purple doesn’t seem to be caused by the minus-green filter. It was doing the same thing before I put the filter on.
