I’d be in for a couple if you went this route, especially if the C01S was also BLF.
interested in 1
I’m interested if it is a good red.
What is a good red for you?
Interested.
in for 1
any chance these will work with a 10440 ?
ouch, these are 2V leds that should not handle more than 1.5A. so on a 10440 either the led gets way more current than that and blows, or if the driver is made for it on average 2W of heat must be dissipated by the driver which is rather steep.
Like Djozz already said, not a good idea at all. These red LEDs have a very low forward voltage and are way more sensitive to heat and overcurrent than SST-20 for example.
You could try using a 10440 3.2V LiFePO₄ battery (if these exist) but still the odds are quite good that...
In for two. Thanks!
Interested, thanks Lux!
okay thanks for answer, i realized it was kinda a stupid question afterall im used to the olight i3t it can run 10440 so ill stick with it then.
Some statistics per today...
78% fulfillment rate of Sofirn's MPQ,
96 people interested so far,
156 pcs accounted so far,
equals 1.63 Sofirn C01R per each member :-D
Please add 2 more to my original post #66
i am interested in getting 1!
One for me in each tint (if there are more than one).
For now, I would count this as one piece since I cannot guarantee that Sofirn will be offering two red tints.
Bitte, leg’ mir noch einen drauf. Danke
Met het grootste plezier, Henk4U2. :-)
Im in for two
