Good comparison at a good time considering Sofirn’s national holiday sale.
Thank you very much.
The comparison is very useful. I have the original model SC31 and I did not know what are the differences with the new version of SC31B. Interesting is another distribution of power levels and increase the maximum power to 1000 lumens. I modified my flashlight slightly. He replaced the tube and now I have a Sofirn SC31 mini flashlight for 18350 battery.
Have both as well.
The older SC31 has a much rosier tint compared to new SC31B.
But the new tint is nice bright white.
Non scientific Quick ceiling bounce test in the small Toiletron test space using both factory supplied batteries at 4.10 volts yields approx this;
Please keep in mind cooler tint is giving more bounce back so it is no real surprise that the SC31 readings are a little low.
SC31
Low 8
Med 160
High 490
SC31B
Low 18
Med 180
High 500
Turbo 1060
Later,
Keith
That exactly mirrors my observations. In informal testing, the B has a cooler tint, a more ‘standard’ looking power button, and for lack of a better term, a Turbo mode at the end of the standard brightness levels.
This is great. Thank you for the quick overview.
Very useful information. Looking forward to receiving the SC31B.
I wished that the new version would have reserved the long press from off to the lowest mode instead of switch-breathing. The breathing function is much less important to me and could be activated by a triple-click or so.
Also, I like the construction of the switch plate with 4 small screws, pity that they abandoned that.
Also, I liked the lower max of the old version that is sustainable without any thermal regulation.
Conclusion for me is that the SC31B, with all Sofirn’s good intentions, is moving towards what any other tube-style 18650 light is doing. For me that is a downgrade.
For those with no lights at all, SC31B is a serious BUDGET UPGRADE for the muggles on the planet. Get it while you can.
The bezel on the new version is easy to open up with a strap wrench. I couldn’t ever get the old version to budge .
The UI needs improvement, nothing fancy just simple shortcuts to low, turbo and strobe would suffice.
All in all it’s a great gift light.
Double click from on or off for strobe
The UI is just fine for the intended user … your mom
Considering that it comes with usb charging and bat this light is cheaper than a convoy s2+ Or clones once you add in those costs
And is more user friendly overall when you consider they dont need to take out the bat and plug it into the charger
If the reliability holds up as well as sofirns CS then its fair to say that this light would be yardstick against which all simple sub $20 dollars 18650 lights should be judged against
Not to mention there no big purple halo around the beam like my s2+
SC31B from Amazon US from Low to High:
Ambient = 725.7 Lux, CCT = 6752K (Duv 0.0010)
Color Rendering Index (Ra) = 65.4 [ R9 = –33.4 ]
Ambient = 6218.6 Lux, CCT = 6820K (Duv 0.0006)
Color Rendering Index (Ra) = 65.5 [ R9 = –32.4 ]
Ambient = 17191.5 Lux, CCT = 6771K (Duv 0.0007)
Ambient = 40755.6 Lux, CCT = 6635K (Duv 0.0014)
Color Rendering Index (Ra) = 65.8 [ R9 = –33.0 ]
Thanks for the comparison.
I should receive my SC31B in two days.
I also would prefer direct access to low from off, but couldn’t pass up the Sofirn combo price for the SC31B.
Just thought I’d add that the SC31B lumens tested on High are no greater than 760 840 at turn on and 720 815 at 30 seconds. This is the cool white version. The 4000K version would be even lower
Modes are Eco, Low, Med, High
Measurements taken a a PVC lumen tube calibrated with maukka lights. Battery used was a Samsung 30Q
Has a firmware bug currently where turning off on Medium switches back on High
Yet again another overrated flashlight from Sofirn. They used to be almost spot on when they first began.
EDIT: cleaned, re-calibrated my equipment and used a new 30Q for the new lumen measurements above.
And yet no one cares about the firmware bug or the “700 lumens” (ill wait for a few more testers to confirm)
It is literally the best deal simple to use USB charging lamp right now
Haters can hate, but ive given a few to “muggles” and they dont give a damn about what some flashaholic thinks
Very few know it’s 700 lumens. It’s good to actually know what you’re buying so you know a genuinely rated light at 1000 lumens is a better upgrade in the future.
I’m trying to do my best fighting a marketplace filled with fake ratings. I’m probably one of the few store owners in the world that sell lights at their true rating.
Oh you mean yr test tube numbers that dont mean a thing in the real world?
I mean BLF flashaholics swore up and down that the sc31b has no stepdown, yet they COULDNT EVEN NOTICE a halving of lumens by eye
The difference between 700 and 1000 is minimal in real world usage
Maybe you should “go after” convoy for their RECURRING biscotti issue that bins the light into a single mode group
Now THAT is a real firmware issue for the last 3 years, yet convoy keeps selling lights with the issue
Do you even own a sc31b?
The thread you linked to has my video actually showing the test of the step down and lumens lol so that must mean I own one. I also sell them.
I love the Sofirn lights, I sell almost every model but I’m still going to test and post the results.
I’ve heard about that issue on the Convoy’s yet I’ve built and sold over a hundred flashlights using that driver and haven’t seen it myself. Just like ToyKeeper says that it happens randomly on some but not all.
Are you gonna go after convoy for their “lies” lumen claims on the s2+ too?
I mean not only is there a firmware issue that locks the light, they only put out around 700 lms too on the 8x7135 despite claiming “1000”
The sofirn “firmware” issue is pretty benign in comparison
Theres been 3+ instances of newly bought s2+ on here and reddit in the past 2 months having this issue
Notice how no ones is helping the poor guy
Time for you to take the flamethrower to convoy!!!
Why do you have such a sour attitude? I’m only reporting my tests. How is it different than a review on pros and cons?
You sound like a Sofirn fan boy that can’t handle hearing a little criticism.
Maukka posted that his 3B tint was likely a 4C by mistake which tested 720 lumens on my same light. The Cool white variant tested at 860 - 900 lumens on mine which varied between different builds.
I report on Convoy, Astrolux, BLF among others just the same. I sell heaps of brands.
