Thanks for the offer Erik! I am definitely keeping you in mind for a custom P60 drop-in or even just a custom programmed driver (think I'd like Medium a bit higher than the usual 30%, or even 4 brightness modes) for another mod.
100 minutes vs. 70 minutes sounds considerable (for my application), so therefore I don't see the gain of 50 lumens worth the 30 minute trade-off.
Don't want to be a spoilsport but please remember that Match's curves are only valid for a heavily cooled emitter. The top points for the curves in real life lies at a much lower amperage because of the generated heat .
[EDIT]: Calculations using Cree's derating curves give me for a "normally" cooled flashligt a top on the curve at an LED output of:
370-400 lumen @ 1.8A for XP-G R5 and
730-780 lumen @ 3.5A for XM-L T6
but the top 30% of the current only add about 12-15% of light output.
OTL (out of the lens) output normally are about 80-85% of the LED output.
The initial star mounted test for the xr-e r2 is complete. The first post has been updated to include the graph. One of these days I'll go through and clean up that first post.
Thanks again to Dthrckt for sending me the emitter for testing....and yes, I'd like to someday get around to testing the new Cree flavors too... I don't need the money, but if y'all could somehow paypal me "15 minutes" that would really help :)
Thanks Match! So it's not worth going over 2.0A. Guess you didn't test it to the point of "pop, burn, fizz, fizz". How was the heat generated at 2A? Manageable for a decent heatsink setup?
In a typical star mounted application, regardless of whether or not the led star is mounted on 3lbs of copper or not, the answer to you question is no...not worth going over 2a. If it responds anything like the xm-l did, then the bottleneck is the star. As soon as I get some time, I'll remove the xr-e and directly mount it to copper and retest.
There was no reason to take the xr-e to failure, as the breakover point for output was 2.1a. More importantly, I want it alive for the afformentioned test. As for the heat, think of it in watts for easy comparison. 2a x @4v is about 8watts. Compare this to @ 9.5-10w for an average driven xm-l.
great work, Match! this has got to be THE most useful thread in the 'flashlight web'
As for the XB-D and XT-E, Cutter doesn't have any 4 xb-d PCBs. I suspect the one up versions of each will find some niche w/ beam profile or tint, and maybe eventually price, but I doubt we'll select them for throw or high output. Still, the data will be useful when you do get around to it.
I, for one, will be much more excited about the direct copper mount results :) Still, you shouldn't feel pressured, that would take the fun out of it, and if that happens, what's the point!
I hear that! I spend so much time fixing and maintaining my 'stuff' (particularly IC engines and whatever they're bolted to) that I don't feel like I own it - it owns me!
It's already been asked a couple fo times and I can't see a reply, but are you/would you consider testing a SST-90? The interest is huge because so many of the Chinese lights are under driven at 5-6As, where as the quailty units (Olight, VP2000, custom builds) hit out at 9-10 amps plus. It would be interesting though to see just how much difference it makes between the levels regarding lumens output. I shy away from buying the cheaper lights due to the amount of drive but if there is really little between, then maybe there is little reason not to try them.
