Does the Wh counter also work if you use the normal positive (red) terminal? — yes, it can, but I still suggest you use the green, because it is special interface for charging the battery …
I often charge batteries with a standard CC/CV supply and 0 problems (I am the protection).
It would be helpful to provide a detailed explanation of what the green terminal does and does not.
of course , it can do that , it just remove some unnecessary function , and add some protection for charaging battery
so if you want to charge battery, please use green port
you consider to buy one ?
In this video, we show some data you want to see
we show battery charging operation and reverse connection first.
then we check the output voltage/current accuracy and output ripple. 100mV VPP
Finally we test the working temperature under full output(60V/6A)
room temperature 36.5℃, panel 62℃, AC-DC power supply 46℃.
RD6006:https://www.aliexpress.com/item/4000282551930.html
my email: 1749808860@qq.com welcome to contact
Now we test the ripple and charging , if there is any one want to see , please let me know , i will show that
customer DIY based on RD6006
link: https://www.aliexpress.com/item/4000282551930.html
Just recently, I want to make a workbench and need to buy some equipment, I like this big colorful screen. As I work overtime on National Day, I just want to give myself some compensation.
The delivery speed is also fast. It arrived in a few days. It has been there since I opened the box. I have no idea about how to do the shell.
There are two cases on the official website, but the small one I have no suitable battery and the big one, 31cm is too long for my desk
So I decided to make the case myself
I have a power source :GERM4815T 53.5v15a, good but it seems too large
and a friend give me advices, here is his plan, after I got it , I think it is not what I want!!
300w 48v, and use converter to 70V, suitable for RD6006 input, and I design the case
go to sleep, leave the 3D printer working
get up, still working
assembly
Painting the outer casing
after assembly, have a test, it can work
add a light strip
emmmm, seems out of fashion
make a new upper board and final apperance
looks cool maybe I should carve some patterns
I just ordered an RD-6006 + S06A + the recommended power supply.
I was planning to reuse a massive Astec 48V@4A + 18V@11A with a DPS 5020. I would have had to switch between the 48V and 18V inputs. The surplus case I was going to use is big, ugly and heavy. RD-6006 and matching case will a better fit for my work bench.
This used to charge the batteries in a patient monitoring trolley.
who have any question for our products ?
RD6006 accuracy test from customer
customer feedback about the accuracy of RD6006
customer feedback to show manu page and unique boot logo
www.youtube.com/embed/a_RqywcOPOE
RD6006 feedback:
use RD6006 to make a power supply, looks nice and performs well, waiting for higher current version
Does the RD6006 have low or high side current measurement shunt?
Does it cut negative or positive in off state?
if the green terminal has more protection, then when do you have to use red terminal ?
Hi friend
thank you very much for your message
let me answer your question one by one
1, we use low side current measurement shunt
2, positive
thank you for your question
1, green port is for charging battery , have more protection for charger battery, but less some function than red port
so as our suggestion, if you want charge the battery, please use the green, if you use it as power supply, please use red
use three power supplies connected in series as input power supply, a complete powr supply comes out, enough for battery charging(it is risky,be carefully when do that)
DIY case! looks nice just heavy(I want that)
make DIY case myself, looks simple but useful
