I like the styling of the SP33 much more than the EC01 but EC01 has the “advantage” of being a more compact 21700. Also for muggles, the SP33 has a much simpler fool proof UI. Everytime I lend my Anduril flashlights to muggles, they always end up in some blinky operations.
I modded the SP33v2 with 4xE21A and the tint was magnificent. Does anyone know if the SP33 uses 3v or 6v XHP50.2?
@Lux-Perpetua Thanks for those details! This forum is better than the product descriptions.
@RobinVC Where did they announce? I searched before posting but didn’t find anything. Great point on the Astrolux EC01, that is also a contender. The regular pricing seems pretty similar except that the EC01 is on sale now at BangGood. Another difference is the EC01 has an 5000K option.
@SKV89 Anduril as an open-source third-party firmware sounds really cool to play with, but as a muggle myself I like simplicity. The SP40’s UI seems perfect to me if it just added a moonlight mode accessible from off, plus maybe a nice “breathing” mode like the SC31(b).
Sofirn’s 26650 HD battery has too much voltage sag to even get close to 3500 lumens. Best to order the SP33 V3 without a battery and get something better. Even Sofirn’s 21700 has heaps of sag at 15A.
Slightly OT: I like the 26650 option as the greater diameter of the battery tube feels much better. Really hope to see such lights in the future, even after 26650 will be abandoned.
Nope, same here. I would've took the boost driver with the new UI changes, but.. ordered one regardless.
I also don't like the 150LM Low in the stepped mode, but that is passable, as I'll only be using ramping anyways. Still bugs me why they've chosen again such bright Low level.. :|
Greetings Gentlemen,I'm new to the forum.I ordered an SP33v3 from the AliExpress Sofirn Store on 11/13/2019 and it arrived 2 days ago.
I ordered it with the Sofirn 26650 5500mAh battery being that it was a very low cost addition and I own zero 26650 batteries at the time of ordering.The total cost was $32.79.
The box was a bit crushed but the contents were OK when delivered.In the Sofirn box was the SP33v3,1 x 26650 battery,1 x 21700 battery sleeve,1 x lanyard,user guide in 3 languages(English,German,Russian)and a business size thank you card.
Also in the box was a USB A to USB C power cable and 2 O rings that were in the zip lock bag with the lanyard.
The battery was at 3.75 volts and charged to 4.2 volts in an Xtar VC4 @ 1 amp.The volts was confirmed with 2 voltmeters.
A capacity test was performed with cutoff set at 2.7 volts resulting in a 5569mAh reading.After a second charge to 4.2 volts the capacity tested at 5603mAh.
I don't have no way to test lumens but the light in turbo is much brighter than an SF11;the high may also be much brighter.I feel the the light emitted is a bit on the warm side with a dash of yellow/green.
The Sofirn 26650 battery is not a tight fit,there's a bit of wiggle room.An 18650 is loose in the supplied battery holder so it will probably be much better with a fatter and recommended 21700
I have a lot to learn about this flashlight before I place it in my SUV.The size is good for the center console.
