Au contraire, with all due respect. ;-) In my opinion deep red is most appropriate for lowlight scenarios where someone needs close-range illumination without causing too much attention (= without being seen). For instance, this could be very useful for reading a map in full darkness without giving up the human eye's adaptation to darkness. It could also make sense for having light in your tent while camping without attracting insects (that are less or even not able to perceive this wavelength).
Policemen or soldiers may appreciate the fact that 660nm is less perceptible by someone standing nearby. So, with regard to a tactical flashlight that Sofirn may want to develop, an auxiliary red light with deep red tint might be the right thing. It's not about high lumens here. Most red (auxiliary) lights are way too bright to be useful without giving up night vision capability, e.g. Wurkkos WK30 or Nitecore P18. A sublumen or low-lumen red light would be much more reasonable.
After all, I think we can agree to disagree. But maybe we only have two different perspectives how useful deep red light can be. :-)
I wrote down the argumentation because there is a common belief that deeper red is better no matter what (some people even want 720nm what we almost do not see at all), while in fact there is a strong trade-off in visibility. Any good reason to precisely want 660nm over 625nm despite the lower visibilty is ok to me though.
The deep red (660 nm) light would be far more useful to me. So if Sofirn produces these, then then I would like two more (for a total of 4). If only the 625 nm orange-red light is produced, then I will purchase only two. Thanks!
Lux-Perpetua, thanks for project-managing this for us! You are the man!
I would not be surprised if the 645nm and 660nm emitters you saw were actually the same wavelength, reported two different ways.
Some manufacturers or retailers list the peak wavelength, which is where the maximum output occurs on an optical power basis.
Others list the dominant wavelength, which is where the maximum flux occur on a luminus basis - it is adjusted based on perceived brightness according to the luminosity function.
It appears a peak wavelength of 660nm from a monochromatic LED works out to a dominant wavelength of about 645nm.
On the other hand, I am skeptical I could tell a 660nm peak LED from a 645nm peak LED.
Oddly enough, Cree’s XP-E2 datasheet lists dominant wavelength for the red, but peak wavelength for the photo red. So the two are slightly closer in practical terms than the stated wavelengths indicate - the red has a stated dominant wavelength of 625nm, but from the spectral graph, the peak appears to be about 635nm.
The XP-G3 datasheet, in contrast, lists both peak and dominant together for the photo red.
That makes three C01R for you if I counted correctly. The odds are quite good that we get to see the deep red tint as Sofirn applied for a MOQ of 1.000 pcs XP-E2 deep red 660nm. Since Sofirn is quite busy now and there is no information when those XP-E2 deep red will arrive in their factory, we need to wait for an update from them.
