If I recall correctly the ‘ramping’ driver that Simon supplies with the SST40 C8+ does not have thermal management. The ‘4-modes’ driver does though :+1:
I have both the “C8 with Biscotti 7135x8 XPL-HI 6500k” and “C8+ with ramping driver and SST40 6500k” and the perceived difference in light output between the two is substantial. The SST40 throws just as far as the XPL-HI does but offers a wider hotspot and more spill. If you do not care for battery life go with the SST40 version. If you prefer better battery life and tighter beam go with the XPL-HI :+1:
I’ve found an XM-L2 running at 4 amps gives a really nice amount of light in a C8 and there are stacks of tint options… But if you are thinking about a bit more power you might want to take a look at the M21A & L21A
Both have the Xhp35.2 an SST40 options
The M21A is really not much bigger than a C8+ but gives you a 5000mah capacity
K ,I like FT03 body, and now I’ve got the sst40 and xhp50 version. I’m thinking that could improve throw ,or at least maintain it with a xpl hi ,where I can choose the tint , in my case 3000k ,which I really need and like. What do I need to switch the led? New driver, 16mm or 20mm, new center ring? Thanks
just wondering, how comparable is the battery life between the sst40 vs the xpl hi? I ordered the C8+ SST40 5000K and have some samsung 35E 3500mAh batteries for it. Is the battery life reasonable?
is it perceived as a big gap though? I thought lumens weren’t really a linear type of relationship in terms of magnitude of lumens and perception of brightness.
