PM inbound.
Even with interest, I’m having a hard time sourcing the sw27 which is why I’ve closed the GB for that.
PM inbound.
Added. We’re at 150 pcs!
sw45k (4500k, below BBL) group buy:
50 pcs aZhu
20 pcs pol77
10 pcs candor
20 pcs rahdi
50 pcs gcxmr2
So I reflowed 3x SW30 on a MosX 3535 triple MCPCB, driven by a LD-B4 driver set to 6A max current. This is by far the best 3000K tint I’ve seen… The tint shift between low and high current is much better than the SST-20 3000K HD2 emitters. I should have ordered more SW30 emitters! Thanks azhu!
Glad you like them! It still surprises me how popular this emitter is today despite it being so very old. Most of my favorite lights still have the 219b in them.
I would like 5 of them.
azhu: gcxmr2:I’m in for 50 pcs of the sw45k.
Added. We’re at 150 pcs! sw45k (4500k, below BBL) group buy:
50 pcsaZhu20 pcspol7710 pcscandor20 pcsrahdi50 pcsgcxmr2I would like 5 of them.
Added:
50 pcs aZhu
20 pcs pol77
10 pcs candor
20 pcs rahdi
50 pcs gcxmr2
10 pcs trelos6
05 pcs The_Driver
219b still going on strong yes. the SW45 got us all.
KevinZA1988:So I reflowed 3x SW30 on a MosX 3535 triple MCPCB, driven by a LD-B4 driver set to 6A max current. This is by far the best 3000K tint I’ve seen… The tint shift between low and high current is much better than the SST-20 3000K HD2 emitters. I should have ordered more SW30 emitters! Thanks azhu!
I’ll take 15 of the sw45k
Hey… put me down for another 5 of the sw45k
50 pcs aZhu
20 pcs pol77
10 pcs candor
20 pcs rahdi
50 pcs gcxmr2
10 pcs trelos6
05 pcs The_Driver
15 pcs flightless22
05 pcs mattlward
intradested
intradested
Which CCT and how many are you interested in?
I’d be interested in three each of the
3500k sw35 d200 L2 r9080
and
4000k sw40 d220 L2 r9080
How much would shipping to Germany be?
contactcr:Probably not. You are testing the worst combo though. Low power, smo reflector and AR lens.
I bet if you remove lens and use a 14500 it will be less bad ( but still not FA3 )
All just a guess though since there’s only limited data for FA3
I actually recently got a DC Power supply. Haven’t tested it out yet.
I also just remembered the lights were all tested with dc fix on. I bet that had something to do with it.The SST-20 I tested was from a J4 flux bin. I also have J5 flux bin that I will test tomorrow probably.
I think you should edit the OP to get rid of the FA3 bin because it will mislead a lot of people. What you tested is very likely a FB4 tint.
and
PM sent
azhu: contactcr:Probably not. You are testing the worst combo though. Low power, smo reflector and AR lens.
Yes you’re right. Source for that supposed FA3 bin wasn’t confirmed so I’m not 100% certain it is correct. I’ll edit those images out later tonight.
UPDATE: sw45k group buy successful. Expected delivery on Nov 18.
azhu, could I buy 10 of the new sw45k batch from you?
Yes that shouldn’t be a problem. PM sent.
PM sent.
