Sofirn C01R deep red [sold out, discontinued]
Sublumen-mode would be great!!!
Interested in one deep red version.
Please put me on the list for the second one.
Good news: Sofirn has received 20 samples of the XP-E2 deep red (660nm) with the bin code XPEBPR-L1-P20-30-B-01 from Cree. Engineering is now starting to build a prototype.
I also asked them to try making the C01S driver programmable with reversible mode order. They said it was possible (3 modes, 2 mode groups). We need to wait and see if there's any sense in having three modes on C01R as deep red tint probably needs 2 modes (low and high) only. But it could be useful for the brigher, more performing versions, e.g. with SST-20. The bad news is that prices are expected to increase with a more sophisticated driver and more LED options. However, this will all be reflected in the poll I am going to create later on.
Easy solution: 9 twists to change both mode layers from lo-mid-hi and hi-mid-lo to mid-hi and hi-mid.
No offense, but I'd rather keep things simple (and reasonable in terms of costs, too). While I do appreciate a high grade of customization on big lights like LT1 or SP36, I'd recommend not overstraining customers on small keychain lights that will mostly be used in one mode-configuration forever. ;-)
That wasn’t offensive, Thomas. All good, just made a proposal. Will shut up now :wink: .
If 3 modes are made, I think that deep red lovers could be interested in a very low mode. So 0.1–5–100%
Not sure though, it is not 100% my type of flashlight.
In general it would be nice if a (mode order) programmable driver is made for the C01S, not just for the red version.
Agreed
No worries, it's all good. :-) Your suggestions are always appreciated.
The poll is live: https://budgetlightforum.com/t/-/72855
Everyone is highly encouraged to vote.
I’m interested, one 625m and one 660nm.
I haven’t experienced this myself, as I only have one C01 variant, and it’s not my EDC.
… but …
I view glue as one of those things that is easier to add than to remove. While it’s true that most will never have a reason to open the head, this IS BLF and access is important.
If they do wind up gluing things into place, can it at least be a low to medium heat-released type of threadlocker?
The problem is a small design flaw: the battery tube and the bezel share the same pill-threading, tighten the bezel too much and the battery tube will not have enough threads leftover to reach the driver. They should have made the pill a tiny bit higher (and risk a larger gap between head and battery tube) or create a hard stop for the bezel. Or screw down the bezel medium tight with a drop of glue in the threads. I agree that weak glue should be sufficient.
Please put me down for 1, thanks.
interested
Interested in 2
I would be interested in one for working around cameras at night.
I’m interested in buying 2 of these when they’re available.
I’ll take one. Thanks.
is it decided what color the body host will be or ? sorry if i missed this…
