I would be interested in one for working around cameras at night.
I’m interested in buying 2 of these when they’re available.
I’ll take one. Thanks.
is it decided what color the body host will be or ? sorry if i missed this…
Please, add me to the list for 1.
I’m on the list for 1
Once we get a price I will probably want 2 total
Thanks,
OldSkol
https://tenor.com/view/dictator-film-2012-andrew-astakhov-gif-5999963
Nice to see this progressing. Does someone remembers what I said around 3 weeks ago? Red emitters, due to their low Vf, could be driven harder without surpassing the driver's maximum rated power. Pretty sure the driver could be fitted with a 0.2Ω sense resistor (R20/R200), driving photo red emitters at ≈472.5mA.
2
In for 2 deep red
It's not decided yet. However, Sofirn told me they are unfortunately unable to offer the "wine red" body color most of us would have favored.
Their anodizing factory would probably spend too many efforts in realizing this color. Eventually, costs would become unreasonable, especially at a lot size this small. :-( With that said, we may go with Sofirn's standard red or black color they used for C01S or I could try to ask for a non-anodized body as C01S BLF edition. I'm not sure if the majority of us would like that. I'm reluctant running another poll at the moment since I just started a poll about the new UI (see OP). Another option would be to use Sofirn's new colors they will use for their LT1 lantern, e.g. dark green, desert tan or orange. Whatever the decision will be, it needs to be consistent for the entire batch as a small size batch with multiple color options will be unlikely to happen.
Muchas gracias Barkuti. I will forward your suggestions and ask Sofirn's engineer to check how overdriving the LED will correlate with C01R's heat generation and runtime. From my experience they do put a lot of focus on longterm life expectancy of their LEDs, i.e. there might be some need for further argumentation.
Standard Sofirn red sounds like the best choice
I’d be happy with the standard red also
&metoo
Since we’re talking about red emitters I think it is appropriate if the body also has some kind of red color.
Swapping the sense resistor, or factory customizing the sense resistor for red emitters, isn't overdriving the LED.
As I said before, they could use 0.2Ω or 0.22Ω sense resistors for red emitters and obtain higher output. This driver modification results in more or less matching power output and battery drain figures versus standard white emitters, while boosting the flashlight output. It's a win win situation, the only potential drawback is the need for driver modification, if anything.
Dark green or desert tan anodization will be very wellcome, instead red or wine red, IMHO.
Even I prefer black instead red anodization.
interested
Some comparative figures:
- With SST-20 4000K at standard driving current (R27 sense resistor), maximum power at the emitter: 350mA × 2.77V = ≈0.97W (check typical SST-20 4000K Vf in djozz's test, see below).
- With XP-E2 red at increased driving current (R20 sense resistor), maximum power at the emitter: 472.5mA × 2.12V = ≈1.00W (check typical XP-E2 red Vf in djozz's test, see below too).
Since the calculation is done for the standard red emitter, it is also fully valid for the photo/deep red one (its Vf may even be a little bit lower).
@ Barkuti: I will talk to Sofirn about the sense resistor tomorrow.
A comment on this old graph of mine: it was in the time that I still used a budget luxmeter (Tondaj) that especially gives largely deviated values for single colours so do not trust the absolute lumen values too much. The curve shapes, currents and voltages should be correct.
As you can see in djozz's output graph, Lux-Perpetua, the raw lumens for the P3 bin red XP-E2 went up from ≈53 at 350mA to ≈75 at 472.5mA in the test station, which is quite substantial. A big difference which the photo red will also enjoy.
