hmmm
A fair bit bigger than the GT mini…
Still pretty small… bigger reflector, more lumens and kcd than even my Vin’d GT mini… I’m excited…
This will out punch my Varapower turbo 2.0!
I wouldn’t mind a lower flux bin too but hope the tint is below the BBL. That’s what made the D1S and the GT Mini so nice because of the beautiful A or D tints. Also the Mateminco MT35 / Astrolux MF02 with the XHP35HI has one of the most beautiful thrower tints I’ve ever seen. The XHP35 HI in that light on turbo measures:
I don’t own the GT but I seen pics of it and the tint should be about the same. Any idea where to get these rosy tinted XHP35HI?
Edit: I just measured my MT09R modded by TA with w/ (1) 80cri C4 bin 4500k & (2) 80cri C2 bin 4000k
CCT: 4829K
DUV: –0.0003
Ra (CRI): 80.5
R9: 5.1
Rf: 79
Rg: 97
I’m thinking TA might have put in a 5000K in stead of the 4000K but who knows maybe the reflector increased the color temp. The tint is in this mixed tint light is pretty much exactly on the BBL, which is nice but I like the warmer and rosier tint in the MF02 better.
WOW! What a great looking flashlight. Will there be a 5700K tint? Most people like the warner tints and not sure why. Maybe its my eyes but anything below 5000K looks dull like my X7 Marauder I got last year and it’s been sitting in the safe since then. 6500K is to high and just to much glare. 5700k is perfect in my opinion. Maybe the 25+ years of welding has taken its tole on my old viewers. I accidently ordered a D4S V2 in 5000K last week, Thank you Hank! Hope it’s not like my D4 where everything has a yellow tint to it. I gave away my Imalent DN35 and DN70 flashlights because they had that same dull yellowish tint. Different strokes for different folks I guess.
I think most people tend to like about 4000K-5000K, which overlaps with the color temperature of direct sunlight for most of the day. Sometimes it’s lower at sunset, and in summer or in the tropics at midday, it can be a little higher. It’s mostly subjective preference.
For a thrower like this, there’s an objective reason to go warmer: backscatter. Warmer tints produce less visible backscatter, so you see more of what you’re illuminating and less of the beam.
I have to agree with you and eat lots of words lol My brand new Acebeam X45 came with the XHP70.2 P2 6500k emitters and it just ignites every particle in the air causing a white out affect if its not a clear clean night. I have to hold the flashlight above my head, those 18000 lumens are blinding.
Now consider that’s only 109 kcd. The K1 will be as much as 600 kcd.
The backscatter might not be as blinding with fewer lumens, but cool tints at that kind of intensity make beams that look almost solid. Good for looking cool; less good for seeing things.
Respectfully disagree about the tint difference, I have beam shots of two GT’s, one in warm white and one in cool white, illuminating a water tower in a light rain at 1.9 miles. The cool white is brighter and lights up the tower better in spite of the rain… and I had my wife shining the lights while I went closer to the tower for pictures of the illumination factor. With me 600 yds from the tower the cool white showed brighter and clearer and the pictures clearly showed it.
Fog lights work to undercut heavy fog because they have a flat beam that is focused close to the car. The Amber color is more to not distract oncoming drivers than anything… point them up for distance like your headlights and you will still see a wall of fog, just a different color wall.
The primary reason we see a difference between warm and cool is that the warm emitters are lower powered, thus they illuminate fog or smoke less than a higher powered cool white beam. This is my take on the ~1000 lights I’ve built. YMMV
This will always be an argument because we all see slightly differently, we all use lights to our own advantage as compared to how others use them, so just remember that any advise, including mine, is more relevant to that opinion than to what YOU might do with a flashlight.
I personally would love the White Flat in the new K1 but it’s pencil beam is not as desirable as a broader more powerful beam so I will go with the XHP-35 HI. Of course I have a lot of lights so slotting a new one between what I have is becoming more difficult.
Whether a warm white emitter gets more light downrange due to less scattering/absorption vs the higher output of cool white is one issue, but it’s undeniable that cool white lights cause WAY more backscatter than the usual 10-15% output advantage would suggest and we have the science that explains why.
Cameras don’t function exactly like human eye does in many ways either, so while those pictures might be accurately showing what the human eye would see, they also might not be.
As for my personal experience, yellow sunglasses and flashlights have always seemed to provide more contrast, less glare, and more clarity while being easier on the eyes.
While I agree, that’s caused instead by the eyes sensitivity to blue light causing strain/constricting pupils more, and very likely due to the wavelength of blue light itself being harder to focus on. An easy demonstration of this is to set up a red light and blue light of equal size and relative brightness at night and look at them from a distance. The red light will be easy to focus on and “sharp”, while the blue light will appear “fuzzy” as with certain conditions (like pupil dilation) it is difficult for the human eye to physically get a good focus.
Raleigh scattering is for particles much smaller than the wavelength of the light and is stronger for shorter wavelengths. This is why the sky is blue; light scattering off air molecules.
But fog particles are several microns large, larger than the wavelength of light, and this scattering mechanism is called Mie scattering, which has little wavelength dependence. This is why clouds and fog look white and not blue.
We need some controlled experiments and photographs. I have seen photographs appearing to show both cases, cool light scattering more, and cool light scattering the same.
In a nut shell this is why I told Hank to make an aspheric bezel/lens for this light.
You guys are worried about micro particles in the air? The white hull of the boat I was on was a much bigger obstacle to my vision than the horrible fog we were in. The spill from the light reflecting off the hull of the white boat I was riding seemed worse than the back scatter from fog. If you are truly interested in seeing long distances you don’t need your feet lit up and pupils constricting while you are trying to spot something far away.
Agreed. But I think scattering off particles in the air is usually significant if not dominant, and that source of scattering would not be wavelength dependent.
All I can say is that in my experience and from many beamshots I’ve seen cooler light of the same focus and brightness has far more backscatter. I’m sure there are many variables to it though.
