There are not many information available about the technical details of the lamp. :confounded:
Was there an old style toroid inductor driver in it, or a high frequency with a shielded SMD one?
Yeah, toroid drivers generally runs on low frequency resulting terrible flickering. I experienced that.
The 4.5A You linked is a 2 group driver, like the one I want to replace. This one has higher current, though. But in the lowest mode it always blinks 1 time as waiting for group change command. Annoying.
I think I will make a try with the Manta Ray driver. In the worst case I flushed 9 bucks. :partying_face:
And you're saying I removed 2 of the 4 stack of resistors to drop the output down to about 4amps, are you serious? Because if so, the driver must be a big buck driver. 8 amps in a 2S buck driver is nice, could you please share photos of it? No rush, of course, but take the oportunity to reset the sense resistors (lower it even further LoL), a 3V XHP50 can take that. And we will see if the driver can take the heat. ;-)
No need to feel ashamed or guilty for anything, its our creation so better learn from the experience.
I've taken a look at the video from the ad, looks like its long-necked so long stock focal lenght. Since you changed its lens now it must over-focus, doesn't it?
If the driver is good and the emitter is well heatsinked, it may be a good host after all.
Yes stock lens focus right at furthest point from emitter, with alternative lens prime focus is half way instead so a good 50% closer to emitter, but yes will over focus if you move it out to far, in all honesty with a genuine XHP50.2 fitted it puts out a reasonable amount of light
Heatsink is not great , the head is not connected to the body it slides forward/backward on the body so that large heatsink is basically just for show and does not aid cooling, the metal is quite thin even with current reduced to 4A it still heats up pretty fast
Perhaps 2k lumens is more truthful stock figure, the Fake XHP70’s do put out fair power
The driver has arrived.
I made a quick test just before feedback the order.
It works well with 3V XHP50.2, although the coil tends to whine softly in high and turbo. To be honest, it was just a really quick test, I used a cheap adjustable buck power supply with quite long wires and crocodile clip connections, and it seemed that better clamping decreases the buzz. So the final installation can be better in terms of noise.
Mmm, so you used the 1S/3V emitter hack because you intended to use the driver for long periods on high, isn't it Lacerta?
My 6V XHP50 ≈4A SK98 does good, but its heat path is enhanced and I certainly don't keep it on high for long periods and never out of my hands. On the other hand a triple Sofirn C8F on high with a mid-power 18650 will burn your hand way before its 2m 30s step down if you keep it tail standing. ;-)
I am not a big fan of short lasting turbo levels. :laughing:
Basically the host can handle ~1500 lumens from an XHP50.2 continuously, so the high of this driver with ~1400lm is good, and the turbo is ~2000lm and can be activated separately. This one also have good mode spacing.
Moreover, 6V output buck drivers cannot hold constant current through the whole 2S battery capacity range in high levels, considering the 6V emitter Vf, the battery voltage, and the driver maximum output voltage ( which is ~Vin-0.3V in the best case ).
Finally I started to rebuild the host. And also I made some further tests with better wiring.
The first 3 levels are good. Input values are showing constant output values which are corresponding to the specs. With the 3V XH50.2 50mA, 150mA, and 750mA. For 6V led 100mA, 300mA and 1500mA is specified.
But at high and turbo level… The driver seems to get mad. :person_facepalming:
The input current should be around ~1.6 and 2.4A.
But it’s 3.4A at high and 4.5A at turbo! And the inductor is whining like hell. Seems that the regulation is not working properly at higher levels at the increased Vin/Vout ratio. :cry:
I wonder whether the replacement of the inductor would help this? Currently a 4.7uH is installed.
This thread's been sleeping for a couple months, it would be helpful if you could recap a little bit better what you are trying to diagnose. This is, are you having trouble powering up an 1S emitter (confirmed) with a ∅22 mm Manta Ray buck driver?
You say the driver is pulling (input) ≈3.4 and ≈4.5 A in high and turbo? Could you measure the output figures? That would help to diagnose what is going on. That seems pretty weird but if the thing is really doing its job efficiently the output should be about twice the preceeding input figures (I presume it is being fed with 2S cells).
The inductor may require a swap for better driving 1S/3V emitters (higher inductance). I'm no expert in these matters so wait for some proper connoisseur to chime in.
I did not check the output values since the led base was soldered to the driver. But the led was very bright and dissipated very much heat very quickly.
Another interesting fact. Before this testing, I made another one. The led was also soldered to the driver, and the supply was delivered to the driver through crocodile clips. But the first case the clamping was less firm.
At that case, the input current was ~1.7A in the 4th level and there was no inductor buzz. It is a little high comparing to the expected 1.6A, but still OK. In turbo, the input current was ~3.2A and the inductor had audible whistling.
Previously, I experienced quite similar results when the led was clamped to the driver with crocodile clamps.
For me, it means that any factor which limits the current like wiring / contact resistance helps to eliminate / decrease the inrush.
It seems that the inductor core is saturating and that’s why the PWM controller cannot stabilize the output current. Since the duty cycle is lower than with 6V leds, the peak currents ( caused by higher voltage difference ) should be too high.
And that’s raise a dilemma!
To avoid saturation, a lower inductance needed ( assuming the same inductor size - it’s 1040 actually ). But it also furtherly increases peak currents. To lower peak currents, higher inductance is required. But higher inductance has lower saturation currents.
Of course, using a bigger size inductor is an option, and there’s place to install. The problem is here that there’s a huge selection of cheap 1040s to play with, but not from bigger sizes.
I bought some Murata FDA1254-H-4R7M (half an inch square, 4.7 µH, rated current Isat/Itemp: 11.2/10.2 A) inductors for a crazy mod project more than a year ago, do you think these would do the job any better?
