RD6006 feedback:
good item, it performs well, constant voltage and constant current output, and the WiFi board can work normally, it is worthy to order one, waiting for higher current version https://www.aliexpress.com/item/4000282551930.html
I’m terrible at metalworking. I smashed the bent case into shape using a 7kg barbell and a block of wood. Yes, I hit it with a barbell.
The bent case works better than I though it could. It looks 2nd quality. I will use the new case when it arrives and save the first case for parts or a 2nd power supply.
if you want to reshape the case, you need a hammer to hit the curved place gently, the case material is soft. and waiting for your test, you can contact me if you have any questions when using it, and I cannot see the picture because I cannot access the picture link :person_facepalming:
customer feedback
[In general, the product RD6006 turned out very cool, the control is done intuitively understandable, in 5/7 minutes you can completely understand it, collected qualitatively, does not overheat even when working on Max currents with low voltage(
[Fast delivery and great packaging. The housing is made to a good standard, all parts needed are included. The photos also show the packaging of the RD6006 itself which is obviously not included with this housing.]
This is a very interesting design. I am mostly interested in Constant Current mode and would like to know how fast does the circuit switches from Constant Voltage to Constant Current. In other words, what surge current must I expect on the output if I connect a sensitive circuit to it. Are there large capacitors directly connected to the output?
Thank you
customer review
RD6006 USB WiFi DC - DC Voltage current Step-down Power Supply
[excellent product!!! very well packaged(well packaged for rude delivery, we both don't want to see a broken device, it is a waste of time and money)] https://www.aliexpress.com/item/4000282551930.html
This is a very interesting item.
I’m mainly interested in the graphical monitoring of voltage and current like other more famous DMMs.
Very interesting software for PC …
Can you expect a version with 3.5 “or 4.2” LCD display ?
(I hope he will arrive soon)
and any improvement in voltage and current monitoring?
It works very well both in the laboratory and in the assembly line.
now I am testing one in my laboratory and 4 in assembly line …
Next day I post some other information about my experience with RD6006-W
Any news and specification about higher current version? I have biffy 1KVA transformer and like it made some PSU with that new RD6006. Can you tell me if that the higher current version will have the measure resolution like 1mA in RD6006?
Looks nice and I plan to buy one, probably with different PS and box, but I don’t see anywhere on pictures the female green connector for input voltage: is it included with RD6006? or box? Do I need to buy it separately and if yes could you please provide its reference?
Also, as I plan to use a spare laptop PS which delivers about 21VDC, my understanding is that RD6006 will then be able to deliver only up to 20 V: is that correct?
