Thanks! Iāll be looking forward to it! Ps, I donāt even know what andruil is. Iām guessing itās part of the ui. Anyway, Iāll be looking for a I instructional. Thanks so much!
My 8 year old said āwhatās that? ā. I told him, I donāt know how to use it, but its the best new lantern in the world and we are some of the first on the world to have itā¦blew his mind:)
The folder of full manuals that SBSLIDER posted a link to will give you all the ins and outs.
If you just want a simple cheatsheet, one of the files in the DIY link (see my sig) has a cheatsheet you can print and keep rolled up between the batteries. :+1:
Thank you for leaving your post, as this will indeed help other people.
You canāt see these stickers if they are transparent and cover the entire metal surface as thereās no obvious edge between the sticker and the wrapper. Every seller should use black or some other color.
Using a #2 pencil or thin straw is a great support for rolling up the cheat sheet small enough to fit in the space between the cells. I tried wrapping around a cell, but there is not enough space, which is probably a good thing.
You can try to enable all the 7135ās and configure the ceiling with 130/150. With this you have a similar lumens in the top of ramp with 5x 7135ās and maximum power with double click, like others Anduril flashlights.
A chance to get on the GB list? or or of the batch codes being sent out? If you are already on the GB list, have patience,they are under production now, and they will build them before beginning to send out the codes, (so they can be shipped right away once they are ready.) Also see post #9127, page #305.
Thanks for the warning, Den! :+1:
Iāve been worried about this ever since I first saw at the driver PCB photos. Especially, because I plan to use NCR18650GA (semi-)flat-top cells.
What is your opinion about simply removing the pot? IIRC, it was mentioned earlier, that currently it does not have any real use (it could act as a current limiter for an optional locator LED, which is not mounted by default).
It could be desoldered as a DIY āmodā by the users who want to use flat-tops, OR it could be omitted to begin with (i.e. not mounted in the factory) in future batches.
Iāve had feedback that the Sanyo NCR18650GA gets close to, but does not touch the trimmer.
As I get more feedback or direct information I will share.
