The folder of full manuals that SBSLIDER posted a link to will give you all the ins and outs.
If you just want a simple cheatsheet, one of the files in the DIY link (see my sig) has a cheatsheet you can print and keep rolled up between the batteries. :+1:
Thank you for leaving your post, as this will indeed help other people.
You can’t see these stickers if they are transparent and cover the entire metal surface as there’s no obvious edge between the sticker and the wrapper. Every seller should use black or some other color.
Using a #2 pencil or thin straw is a great support for rolling up the cheat sheet small enough to fit in the space between the cells. I tried wrapping around a cell, but there is not enough space, which is probably a good thing.
You can try to enable all the 7135’s and configure the ceiling with 130/150. With this you have a similar lumens in the top of ramp with 5x 7135’s and maximum power with double click, like others Anduril flashlights.
A chance to get on the GB list? or or of the batch codes being sent out? If you are already on the GB list, have patience,they are under production now, and they will build them before beginning to send out the codes, (so they can be shipped right away once they are ready.) Also see post #9127, page #305.
Thanks for the warning, Den! :+1:
I’ve been worried about this ever since I first saw at the driver PCB photos. Especially, because I plan to use NCR18650GA (semi-)flat-top cells.
What is your opinion about simply removing the pot? IIRC, it was mentioned earlier, that currently it does not have any real use (it could act as a current limiter for an optional locator LED, which is not mounted by default).
It could be desoldered as a DIY “mod” by the users who want to use flat-tops, OR it could be omitted to begin with (i.e. not mounted in the factory) in future batches.
The trim-pot resistor at this time is dormant, and it could be possible to remove it if you wish. as it was a feature added for modders, it has been discussed by the team and its likely it will be relocated in the future lots.
