Reserved.
How many 18650 does it take?
It can not be “One” with all that output!
2 section/4section/6 section/8 sections??? Are these extensions which are also associated w/ how many 18650?
So Haikelite isn’t dead. Their website is, so I had been wondering.
This is the first I’ve heard of the SST-70. There’s an output test by djozz showing similar output to the XHP50B until significantly overdriven, and a smaller emitter area for more throw.
Yes, I would like to know as well!
HT70 uses 2x/ 4x/ 6x /8x button top high-drain 18650 batteries.
Looklike 2s are directly drived to the LEDs
The tube is quite long for 4*18650, i hope it is 4*21700, it’s easy to find high drain 21700 with high capacity
Btw, I’m in
They is a super fair price for a light that has decent lux and great output.
I’m in! code please
Price is similar to our previous MT09R gb. I will pm your guys the deal tomorrow (10th).
Thank you.
Description states 5000K OR 6500K. Banggood only gives 6500K option?
1.Any idea what kind of step down and when?
.Thanks
I want one.
Redlyne22:They is a super fair price for a light that has decent lux and great output. I’m in! code please
I am IN “IF” it indeed comes in Neutral White. :sunglasses: NW Please. Code Please!
I am surprised no one has asked these important questions.Especially #1 and #2.So I will ask them.
1. What is the UI
2. What are the Outputs of the other mode groups?
3. What type of battery carrier if any is used? 2 X 4 carrier with option of using 2/4/6 or 8 batteries?
4. Are 10Amp high drains enough[ MJ1 OR GA’S]?
Off hand the Only 3000mAh high drains I can think of is the 30Q,LG HG2 and the VTC6.
IF 10amps are enough I would prefer the 3500mAh GA’S OR MJ1.
Thanks
1. What is the UI
Thanks
1. ?
2. ?
3. No carrier; one piece battery tube design. All positives face towards driver. All negatives at the springs in the tail cap.
4. 10A like GA is definitely enough. However, there is a chance it uses a FET drive, so you could get a tad more output with something like a 30Q or VTC6. But I doubt you would notice the difference with the naked eye.
From Djozz’s test the output is pulling around 7 amps per LED.
BaronVonEissler:I am surprised no one has asked these important questions.Especially #1 and #2.So I will ask them.
1. What is the UI
Thanks
1. ?
2. ?
Thanks. I have 8 X GA BT Protected that have about 25 cycles and have been stored since last November…….now they can have a home!
Thanks. That seems to confirm that 10Amp GA’S are enough.
Interested!
texas shooter:From Djozz’s test the output is pulling around 7 amps per LED.
The current going through the LED is not the same as the current going through the batteries.
There is a possibility that it is not going to fit, as protected cells are a bit longer than unprotected cells.
Interested in Code for nw grey or sandy Version ... Need a Battle to DT70
