Thanks. I got 2 for $11 shipped.
I just ordered one. Free is better than cheap. Thanks for the tip
Added a second one for $10.80.
Did the 70% from amazon stop? I initially clicked the amazon link and saw it there but closed it and went to vipon and claimed code then went back to amazon and it’s not there
I snoozed, I losed. Hopefully the coupon renews tomorrow. By the time I got there, the Vipon page reported page not found. There’s nothing to be found searching for “Garage” either.
I ran into the same thing.
Hey All,
When I went to the Rossman Repair website to compare their price on 30cc of Amtech Solder Flux with the same on Amazon, I noticed this Extech MN25 DMM for a mere $8.04 (regularly $32.99). So as a hobbyist who only needs a DMM occasionally for checking the basics like voltage or resistance, this seems like a deal worth consideration. For the community's electronics experts, is the Extech MN25 worth purchasing for at least checking battery voltage, or as a backup to your backup DMM, or for gifting to someone just starting to learn electronics where a high-end DMM can be very intimidating, etc.?
BTW, the Amtech NC-559-V2-TF Tacky Flux, 30cc purchased through Rossman is $21.23 (including the plunger, needle tip + S&H to Michigan) versus $29.99 on Amazon. Although shipping could be potentially slower, saving more than $8 is worth it to me.
-KSM
Extech makes some high quality products which this is probably on the bottom of the price list I would still think its a decent product.
For your all purpose hobby measuring it should be fine. Auto-ranging is a nice feature if you ever decide to move on up the electronics ladder.
Its been more than a year ago since I ordered any Amtech from Rossman, but I dont think it took to long to get here in NC.
One thing I did with the 30cc syringe was to dispense some of it into a smaller 10cc syringe from tractor supply. Filed the needle tip blunt to keep from sticking myself. Makes using it very convenient, no mess, very easy to control the amount and no cap to put back on. Doesn’t come out unless pushed.
https://www.amazon.com/dp/B075M9DXJF
Morpilot multitool + zoomie. Both quite solid, both really nice.
20bux + 30% off coupon, which is even cheaper’n the vipon coupon I got mine for a ways back.
Speaking of multitools this one on amazon ends up being $3.50 to the door with prime.
https://www.amazon.com/gp/product/B01A0QZ30U
Vipon has 70% off code and amazon has a additional 5%.
https://www.vipon.com/product/5493868-Jakemy-Portable-Folding-Pocket-Knife-with-amazon-coupons
It seems popular with lots of reviews.
Thanks. Not expecting great quality at this price, but couldn’t pass it up at $3.50.
Use subscribe and save and its even lower…
Olight S1 Mini 5500K high CRI XP-G3. $34.97. Olight cell included from Skyben. Nice deal on the little guy. No coupons or codes.
https://www.amazon.com/dp/B0774DJ551/ref=twister_B0774RBLC6?\_encoding=UTF8&psc=1
Ordered the Wuben E19, last night, code still works, thanks Active Al. Will receive on Monday
Lol, pitch the light, use the accessories and still come out ahead!
Ruspike 1300 Lumens Tactical Flashlight Kit, 1300 Lumens Super Bright LED Flashlight 5 Light Modes, Adjustable Focus, Water Resistant – Rechargeable Battery, Charger (8 Pieces Sets)
$26.99 -> $8.99 Full Package Include: Tactical LED Flashlight (Ultra Bright, Zoomable, Adjustable Focus)360° Rotation Clip Soft light lampshade + Flat lampshade+ 3 AAA Battery tube(black or white random)18650 Battery Charger + Package box (Suitable as a gift).
Do Not Put the Battery Out Completely!
The Wuben E19 penlight is on sale for $14.84 with code 7DJ3B9AA. Features:
Emitter: Nichia 219c
CRI: >90
Color Temperature: 4000 K
Max Output: 200 Lumens
Max Beam Distance: 55 m
Max Runtime: 80 hrs
Battery: 2*AAA
Modes: H (200 ->40 lm), M (50 lm), L (10 lm), Eco (2.5 lm)
Special Mode: SOS (hidden, tap three times to activate)
Mode Memory
Length: 140 mm
Bezel Diameter: 14.8 mm
Tube Diameter: 14.8 mm
Weight: 23 gm, 48 gm with batteries
Waterproof: IP68
Gold Plated springs
SMO reflector
Coated toughened glass
With this AAA light can you use 10440 batteries in this?
New to lights and this came in today and curious if I should order some 10440 batteries to use in this.
No sir.
Not sure if I got a bad one, but this Wuben E19 is nowhere near 200 lumens, eats batteries quickly, has a tint shift at about 16” from wall where main spill is rosy then gets cooler on perimeter with an emitter artifact in the center. I like the knurilng and the finish but I will have to compare it to my other pen lights and see if output is really off or if its just the high cri factor, But the 180 lumen Olight I3T is much brighter on 1 AAA
went through 2 pair of duraloops that i thought were charged, but not so sure now, they are kinda old, some newer eneloops getting better output, will retest the others after they charge.
My E19 has a donut hotspot, rosy on the outside with a yellow center. The medium setting is too low, resulting in a large gap between medium and high. Otherwise, it is a sleek design; plenty bright on high, and quality construction.
