New Haikelite HT70 [4 SST70, 17000lm, 1500m, 8x 18650]
Don’t know where you got those numbers from but the HT70 and X65 mini are pretty comparable.
Dabo gave me the data from a UNI-T UT383BT luxmeter who posted the http://tieba.baidu.com/p/6279468226
Freeme group buy info here.
8x 18650? Series or parallel? Is that a requirement for the 1500m throw? This is the best meter per dollar out there it seems?
2 in series, and 4 of those parallel. This determines driver design to power the leds. You can have more throw for less $ than this light, but you’ll most likely have a smaller hotspot, and much less bright spill.
Can you recommend some? Thanks
For example a single emitter XHP35 HI light with decent sized reflector like the Atrolux MF02, or the Imalent RT35. Both are in the order of $80 with coupon.
And for an even smaller hotspot with less bright spill there’s the upcoming Noctigon K1 discussed here: Emisar D1sV2 respectively Noctigon K1 - #48 by Hank_Wang
P.S. We don’t know for sure the HT70 actually does 1500m / ~550klux
I should be able to DISABLE the step down like I have with my FT03 which also has Narsil. Right?
The ad shows that it uses NarsilM. If accurate, then yes, it functions the same as the FT03. I would want some verification that it uses NarsilM, though. Haikelite have tried to make their own ramping software in the past.
I know noth'n bout these NarsilM claims, as usual.
Same for Texas_Ace. Haikelite is doing it on their own (it seems).
Looks like they did not have enough solder paste,flashback from my TN32 where the LED burnt. Thrunite/Illumns took care of me immediately.
Just got it today.Did not even use 2 minutes and I notice smoke under the lens! One of the LEDS burnt.
I EXPECT a Full refund for a DEFECTIVE product. If not, PAYPAL dispute!
Photo right after it happened. Chemical film is noticeable under lens.
Wow! Hopefully this is an isolated case and not a sign that the SST70 has poor reliability/robustness.
My guess is the LED was not mounted on the heat sink with enough solder paste. Same thing that happened to my TN32 on January 31,2014! Exactly 6 years ago,just looked it up. My Grandmom-98, passed away 12 years ago today.
Interesting if this body will work on MF01S.
What do you mean? Use this battery tube on the MF01S head? No, they are completely different.
Woops my mistake, mixed up Haikelite and whatever that OEM Astrolux uses.
I’ll try to fix your post Art.
From Artiet59:
I’m late to this party, any word on how this light is now - 8 months later? longevity-wise?
Did the seller take care of the issue?
Is the throw/lumens adequate or close to claimed? Thanks!
I hope you got your issue solved with the burnt led and thanks for all the quality input on this forum. I’m new, but I see your posts all over here.
Art
I’d also like to hear from anyone else that purchased this light. On a side note. Can these sst70 leds be purchased separately?
