With this AAA light can you use 10440 batteries in this?
New to lights and this came in today and curious if I should order some 10440 batteries to use in this.
Not sure if I got a bad one, but this Wuben E19 is nowhere near 200 lumens, eats batteries quickly, has a tint shift at about 16” from wall where main spill is rosy then gets cooler on perimeter with an emitter artifact in the center. I like the knurilng and the finish but I will have to compare it to my other pen lights and see if output is really off or if its just the high cri factor, But the 180 lumen Olight I3T is much brighter on 1 AAA
went through 2 pair of duraloops that i thought were charged, but not so sure now, they are kinda old, some newer eneloops getting better output, will retest the others after they charge.
My E19 has a donut hotspot, rosy on the outside with a yellow center. The medium setting is too low, resulting in a large gap between medium and high. Otherwise, it is a sleek design; plenty bright on high, and quality construction.
Thanks for the heads up … I just snagged one of these fine lights.
Order Summary
Item(s) Subtotal:$29.99
Shipping & Handling:$0.00
Promotion Applied:-$12.00
Your Coupon Savings:-$3.00
Total before tax:$14.99
Estimated tax to be collected:$1.16
Grand Total:$16.15
I like it better than the Tool AAA. The UI defaults to low with a short ~10 second memory. The mode spacing is good enough. The button is mushier. Knurling is more aggresive. The built quality of the body is on par. It’s around the same size as the old reflector version and slightly larger than TIR lens Tool AAA. Comparison
As for emitter swapping, I believe the pill had weak glue (I can’t remember how much force was required to loosened it from a while back). Lefty loosy to remove. The driver is press fit tightly into the pill (much tighter than Lumintop; I initially thought it was glued). The mcpcb is press fit in place by a plastic retainer that spins with the mcpcb making it difficult to remove without twisting the wires off. The mcpcb has a ‘through hole’ design where the leads are feed into holes from the bottom and than soldered on top. The pill can fit a ~9.6mm mcpcb. Innards
Have the Wuben E01 and it is nice but suffers horrible low freq PWM.
Ultratac has PWM as well in Med mode but not as low freq. Note my Ultrtac is older model so they may have changed.
Do not have a current Tool but do have the EDC01 and the IYP07 and they do not have low freq PWM.
The IYP07 has a nice Nichia emitter as well but that light is slippery but has a clip that is attached around the battery tube so it will not just spring off.
Having said all that I did order 2 more of the Wuben for gifts to people who do not understand PWM and really don’t care so it should work well for them.
The Wuben build quality is incredible for a truly budget model.
This looks like one of the hundreds of copies of branded DMM units. Mine (Craftsman) has been great for the occasional car/motorcycle related uses I have for a DMM. It’s a steal at that price.
CHARMAST - Portable Charger 10000mAh Power Bank with Flashlight Emergency LED Pocket-Sized External Phone Battery Pack This was under 3.00 after VIPON and AMAZON coupon.
