Amazon Deal Alerts & Discussion Thread
I like it better than the Tool AAA. The UI defaults to low with a short ~10 second memory. The mode spacing is good enough. The button is mushier. Knurling is more aggresive. The built quality of the body is on par. It’s around the same size as the old reflector version and slightly larger than TIR lens Tool AAA. Comparison
As for emitter swapping, I believe the pill had weak glue (I can’t remember how much force was required to loosened it from a while back). Lefty loosy to remove. The driver is press fit tightly into the pill (much tighter than Lumintop; I initially thought it was glued). The mcpcb is press fit in place by a plastic retainer that spins with the mcpcb making it difficult to remove without twisting the wires off. The mcpcb has a ‘through hole’ design where the leads are feed into holes from the bottom and than soldered on top. The pill can fit a ~9.6mm mcpcb. Innards
flightless22 - Nice size comparison photo and disassembly details :+1:
Setting price considerations aside, how does the Wuben E01 rate relative to the Tool and Ultratac, if I could only choose one?
Currently even lower, shows as $6.75 (from a seller with decent ratings)
https://www.amazon.com/gp/product/B0012VYKOS
Have the Wuben E01 and it is nice but suffers horrible low freq PWM.
Ultratac has PWM as well in Med mode but not as low freq. Note my Ultrtac is older model so they may have changed.
Do not have a current Tool but do have the EDC01 and the IYP07 and they do not have low freq PWM.
The IYP07 has a nice Nichia emitter as well but that light is slippery but has a clip that is attached around the battery tube so it will not just spring off.
Having said all that I did order 2 more of the Wuben for gifts to people who do not understand PWM and really don’t care so it should work well for them.
The Wuben build quality is incredible for a truly budget model.
HTH
Keith
This looks like one of the hundreds of copies of branded DMM units. Mine (Craftsman) has been great for the occasional car/motorcycle related uses I have for a DMM. It’s a steal at that price.
CHARMAST - Portable Charger 10000mAh Power Bank with Flashlight Emergency LED Pocket-Sized External Phone Battery Pack
This was under 3.00 after VIPON and AMAZON coupon.
AMAZON LINK
VIPON LINK
wow that went quick
wow that went quick
[/quote jigsaw]
no worry, it’s been gone for days
subscribed
The Miboxer 4 bay charger is back on Vipon—code worked this time
https://www.vipon.com/product/6932960-Miboxer-Smart-Battery-Charger-Universal-Intelligent-amazon-coupons
Actually… I bought it again right before I posted. Just need to be quick it seems.
I got my LED garage light. They are bright!!
Yea the garage light is pretty bright. But my eyes are slowly getting used to it
Oh yeah. A little cool, but 2 for $10.80 is ok. One of mine comes on instantly and the other has a slight delay. I wonder what that means?
Mine has a slight delay too…at least the price was right…FREE!
Not sure of the interest — but throwing it out there.
HQST 100 Watt 12 Volt Monocrystalline Solar Panel . 80.99 shipped. lowest price its ever been.
Amazon Link
Imalent DM70 and DM35 are Lighting Sale right now on Amazon US. Only 20 to 25% off though (about $75 and $70).
Don’t have either. Just a public service message.
Imalents
Nice for gifts. But no USB charging, so they have to go to someone close since no one else has a charger. Or will a USB chargeable battery fit? That might be the answer. And no LVP, just low voltage indication. So is it safe if someone puts it in a purse or backpack and it turns on? Still, it will be good for the right person.
Imalent HR20 and HR70 headlamps are a Lightening Deal at Amazon.com until around 12 noon EST today, 15 Nov..
Imalent DX80 is in a lightening deal starting at 12:25 PM EST.
Edited:
Whoa! That’ll sure lighten your wallet! :laughing:
