Why has the temperature blink-out been removed?
I know, the lantern needs no temp control, but especially outside a temperature info would be nice.
Even more so, since the LEDs are far away from the Sensor in the LT1 and the readouts would be more accurate….
I think an argument could be made to swap an SOS mode for either the bike strobe or tactical/police strobe. I almost put Party Strobe in that list, but lets face it, this is the perfect platform to have a party strobe. :+1:
Edit — Long Live the Bike Strobe! With a half-reflector add-on and a bike mount, this would make a rather wide angle bike light.
My vote is to replace the tactical strobe with SOS. I don’t think the two people who might use an LT1 in tac-strobe as a paintball light grenade will complain too much. :sunglasses:
I think both the party and tactical strobe have their uses. Situations may arise where a blinding/confusing bright light would make a good distraction. The bike strobe however… Guess it’s up to ToyKeeper to see what can be done.
With the driver held in by two easily accessed screws, AND there being a pogo-pin contact pad, the LT1 should be one of the most reflash-friendly lights around.
Surely, no one needs a tactical strobe on a lantern and extremely few people even need one on a flashlight; it’s just a marketing feature. I’m not attempting to start an argument, as I’m sure some people think a tactical mode might save your life, but even they might admit that such modes have been over-used to hype even terrible products to a crime-fearing public. It’s even possible that a tactical strobe simply makes your attacker angrier and more vicious.
I would argue that extremely few people need an SOS mode, either, but as much as I hate SOS being a primary mode on most flashlights, I will admit that a hidden SOS, as would be the case with Anduril, could be a useful feature on a lantern. It pains me to say that considering the idiotic marketing of tactical modes .
Oh, and sorry for calling you Shirley… unless that’s your name.
Those look to be the exact same batteries I just recently pulled from a laptop battery pack. Red shroud with light blue surround at positive contact. Sanyo R1122. Took a very long time to charge up, but reached 4.2v.
By the way, I noticed you completely pulled off the tabs. What I saw someone else do is to trim off part of the tab, leaving the rest in place. In this application, that would be an advantage, to avoid snagging.
All temperature-related bits are omitted from the lantern build. This was mostly because it can’t regulate anyway, since the sensor is too far from the LEDs… but also because it provides room for extra features like tint ramping.
Since the lantern has temperature stuff removed, it has some extra room. It should be possible to add SOS if people want it. I’m thinking it should go just after beacon mode, in the blinkies group.
As a side note, there probably isn’t room to include SOS on any other attiny85 versions of Anduril. If it’s added, it’ll probably just be on the lantern.
Yeap those are the batteries that I have. I got those batteries years ago before the LT project was started so leaving the tabs on wasn’t something that came to mind. If I had known then I definitely would have left them on
If you can fit it in there, fantastic! Six of the eight lanterns I signed up for are intended as gifts for boating, hunting, and camping friends. Lake Superior and the Boundary Waters are very unforgiving mistresses. Having SOS in a platform like this would be much more visible for a longer time than say, something like a Convoy C8.
Mine has arrived! So far so good, I really like it. Mine did come with some solder bridge issues, 6 & 7 had been bridged and then unsoldered but one of the extra 5000k bridges was still intact. So, I just went ahead and bridged them all. The only issue is candle mode is now a little overactive but I doubt I will use that mode much outside of the novelty factor.
It could be entirely placebo but it seemed like candle mode was less flickery before I bridged the connections. I think it’s likely due to the fact that candle mode doesn’t go as dim as it did before bridging. This is not an issue at all for me though and I don’t think its indicitive of any problem with the light. I’m also comparing it with my MF01S and MF01S Mini candle modes which are of course completely different beasts than the LT1.
Don’t know about the LT1 but on my MF01S candle mode doesn’t look realistic. Sometimes the brightness changes a bit too much but it’s still kinda ok. Other times it just looks like it’s ramping up and down.
