So, you got my attention with this… Smart Bulb Alexa Google Home Voice Control Smart WiFi E27 7.5W RGBCW Dimmable LED Bulbs
I run Home Assistant as a home automation package. It is very aware of many types of light bulbs, I am wondering if any testing has been done with HA outside of the catchy Amazon and Google platforms? I am not a coder, but if there is any openness to the protocol that is required for the bulb to work… I could be implemented.
It looks like it may be supported through the Tuya Smart Home integration. Would be interesting to test!
I tested some of these products using Sekonic C-800-U. I tested the 4000K before too and I remember it was good but I lost the results and not going to pull the strip out for testing now.
yeah, I see your avatar is sunumbrella, I have already watched All resident evil movies, I think the resident evil 1st is the best, maybe it's the beginning.
Most of Smart led light bulbs support to work with Amazon and Google platforms, but we don't test them, if you have time, could you buy one our smart bulb to test it? We appreciate your help very much.
Thank you for your testing, here is our testing report of 95+ led strip light and 95+ led bulb, the 95+ led bulb has the same led chips as our 95+ led strip light, now the R9 of new batch 95+ led bulb is better than before you bought, the R9 we are always trying best to improve our technology and led chips.
Below is 95+ led chip's daylight white 5550K testing report, RA 97.3, R9 is 99.1
Below is 97+ led chip's daylight white 5381K testing report, RA 98.3, R9 is 99.11
Below is our latest batch 97+ daylight white led chip's testing report from our factory, we used SEKONIC SPECTROMASTER C-800 equipment to test. Because some customers reported that our 97+ led strip light daylight white has slight green tint, so we have already asked our factory's engineer re-adjust the R9, R11 value.
One of our customer analyzed this problem, he said that as below:
I tested this Vs my aperture 300d on skintones and I'd say the colour reproduction is as good however you will notice a slight green tint Vs aperture leds but aperture leds add magenta tints to their elements in front of the LEDs to combat this. 1/8th minus green gel makes it look perfect.
Before buying any of your E27 lights(https://www.aliexpress.com/item/4000214865872.html), I would like to know if you have any pictures of the beam profiles(beamshots). That would be great before buying them.
Thank you for your inquiry before purchase our this CRI 95+ E27 COB LED, we are sorry to tell you that we don't have the pictures of the beam profiles(beamshots), we send some effect pictures to you for taking a look first. Hope you are satisfied with our this products.
The case is aluminum material, dissipate heat is good, no problem.
Do you mean you want to buy our high CRI 90+, 95+ or 97+ SMD5630 led chip, is it right?
Yes, we support to sell this high CRI led chip, but it need minimum order quantity, such as at least 500 or 1000pcs led chips, because one reel from led chip factory has about 5K-6K pcs led chips, hope you understand.
Please free to contact us your detailed information if you really need to buy our High CRI led chips, here is our email address: DIYLEDU-HOME@outlook.com
