Thanks for the review, Old! I may have to pick one of those up. It blows away the ITP in higher modes but equals it in low, very impressive! I had no idea the E09 had such a nice low nor was that bright.
I also wasn't aware of just what a sexy little light that Maratac is.
I Have one on order from Manafont, but don't know when it will get here. Service seems slow, but I expect that from China. I hope Eneloops will fit as that is what I plan to use. Now I am concerned as to whether or not they will.
Thanks for the review. I may order another if we know that Eneloops will fit. The output is surprising to me, but I see it is at the expense of run time.
Has there been a review of the AA model. I also noticed from the Manafont site that there is an extension for the AA that allows the use of two AA. I suppose it would not affect the output but only the run times?
Thank you very much. That was a GREAT review of the Lumintop Worm. Made me want one. I appreciate the comments re the 10440s. I have some on order, and plan to give them a try. I have the iTP A3 and the LD 01.
I am grateful for you who have such a wealth of knowledge and share it with us.
Thanks, Old. It's always interesting to hear a "best of breed" opinion from someone who has several similar lights and can examine them back to back to back.
today i've expanded the section "Disassembly / Troubleshooting." of my review with a few more relevant pix. the reflector of the V2 is glued onto the LED board as before. whoever opens the sealed head (the threads are glued with green stuff!) and then kicks haha against the reflector will tear off the reflector and leave a compromised insulator layer, as before (in V1). I dont expect a better solution in V3 (the manufacturer is aware of my dissatisfaction about their glue); the head will come again sealed (with green glue) which means that the user is not supposed to unscrew the upper head part.
not much force needed. if you ever need to unseal the head (because your Tank "died"), then do it. i have prepared several copies of a circular cut insulator (plastic!!, from a coax) in case i need to (re-)fix the insulation. I am looking forward (honestly!) to installing the plastic insulator in my V3 sample. Once your unit has a plastic or foil insulator, it will never "die" again, promised. It's then really built like a Tank!
