can anyone please tell me the manufacturer/model of the light right next to the EO9?
thanks,
patrick
thanks,
patrick
Maratac AAA
Solid review - great pics - nice torch.
We have a winner !!!!
Another awesome review old!
I Have one on order from Manafont, but don't know when it will get here. Service seems slow, but I expect that from China. I hope Eneloops will fit as that is what I plan to use. Now I am concerned as to whether or not they will.
Thanks for the review. I may order another if we know that Eneloops will fit. The output is surprising to me, but I see it is at the expense of run time.
Has there been a review of the AA model. I also noticed from the Manafont site that there is an extension for the AA that allows the use of two AA. I suppose it would not affect the output but only the run times?
Jerry
Nice review, Old. Thanks for taking the time. If I may, out of the seven AAAs show in your review, which would you keep if you only could keep one?
thanks! Went to their site, nice offerings. Latest AAA, revision 2, is $24.95 BUT they want $10 for shipping! Ouch.
what a beauty though, and 115 lumens.
Hi Kreisler,
Thank you very much. That was a GREAT review of the Lumintop Worm. Made me want one. I appreciate the comments re the 10440s. I have some on order, and plan to give them a try. I have the iTP A3 and the LD 01.
I am grateful for you who have such a wealth of knowledge and share it with us.
Regards, Jerry
it's a fun forum here haha :bigsmile:
Is it true that "He who has the most toys wins?"
Jerry
Nice review ty, I'm not enough brave to start the kreisler's 1 xD
Where to get the v3?
Was a bit on the short side : Was dead tired ... long day at school .
If I hold the light to my ear , there is a faint hum in low and medium ...
I havent checked regulation as yet , and it really begs a clip ...
It really should make for a very nice EDC , some batteries not fitting is some what annoying , but this can be forgiven .
Has to be the N-light B3 , the regulation on it is fantastic on a Nimh ...
Maintains output right to 1v or there abouts before output drops .
My No2 would be the Maratac and my new No3 would be the Tank007 , now if the Tank had a clip , it would be No2 ...
And if it had great regulation , it could be No1 [ but I havent checked regulation as yet ]
is the clip on the Maratac removable?
thanks
Yes it is ...
Thanks, Old. It's always interesting to hear a "best of breed" opinion from someone who has several similar lights and can examine them back to back to back.
Best of breed ?
I think that would depend on what you want from the light ...
N-Light B3 review was on Jayki .....
I may need to re-visit this ...
Anyhow , the B3 just had really nice regulation and efficiency on a Nimh ...
Current VS output = best in class , regulation = best in class ...
Not the brightest , not the cheapest , not the best , [ mine is modified = clicky ] , but after the clicky mod , its just so sweet ...
So for me , its No1 in AAA ...
If you took the N-light out of the equation , the Tank007 would be a serious king of the hill contender ... [ Say budget AAA ]
Thanks for the kindly posting~I bought one on order from Lightmalls.But I didn't know this yet...
Thanks again~
today i've expanded the section "Disassembly / Troubleshooting." of my review with a few more relevant pix. the reflector of the V2 is glued onto the LED board as before. whoever opens the sealed head (the threads are glued with green stuff!) and then kicks haha against the reflector will tear off the reflector and leave a compromised insulator layer, as before (in V1). I dont expect a better solution in V3 (the manufacturer is aware of my dissatisfaction about their glue); the head will come again sealed (with green glue) which means that the user is not supposed to unscrew the upper head part.
not much force needed. if you ever need to unseal the head (because your Tank "died"), then do it. i have prepared several copies of a circular cut insulator (plastic!!, from a coax) in case i need to (re-)fix the insulation. I am looking forward (honestly!) to installing the plastic insulator in my V3 sample. Once your unit has a plastic or foil insulator, it will never "die" again, promised. It's then really built like a Tank!
Thanks for your review!
I’ve obtained my Tank007 E09 today. It’s a rather poor but more pocketable quick replacement for my lost Nitecore D10. Nice little light.
Low-mode users like me might dislike the mode memory behavior:
It cycles high-mid-low modes by loosen/tighten. It remembers the current mode, if it shines for at least approx. 3 seconds. Unfortunately, the mode iteration is triggered not by the short OFF period (loosen/tighten) but rather by short ON period. So if you have set the low mode, turn it on for less than 3 seconds (often enough for orientate yourself in very dark room), next time you turn it on, it shines the HIGH mode. Not very pleasant feature.
