For other Anduril lights I would like to see a momentary turbo like on Narsil. Anduril momentary mode goes to where you last had the ramp set at. It would nice if could go to turbo as well. Hope you can add this to the code sometime.
I just received a PM form Sofirn with a one time code for Amazon. I’m at numbers 813, 814, 815, 816, 2558, 2559, 2560, 2561. Does this mean for one lamp or I have one time to order all the lamps I signed up for, or the first group of 4?
Even having read every post in this thread, I’m unsure and don’t want to jump the line, plus looking forward to possible color options. (Go red!)
And just like that my hopes of giving these as Christmas gifts are long gone. I got a code for one since all my lanterns over #1000 on the list except for one.
Sorry for the off-topic post… This isn’t really related to the lantern. It’s about other Anduril-based lights.
It can already do momentary mode at the maximum level… it just requires ramping up to that level first.
The tricky part is that, on most lights, the highest level isn’t in the ramp by default. And momentary can only go as high as the ramp does. But if this is not what the user wants, the ramp ceiling can be raised with just a few clicks. That’s how I usually configure really throwy flashlights. It’s handy having a momentary turbo on throwers, so I made sure it was possible to do that.
To raise the ceiling all the way:
1 click: Turn the light on.
4 clicks: Go to ramp config mode.
0 clicks: Wait for the second prompt.
1 click: Set the ceiling to maximum.
0 clicks: Wait another few seconds to exit config mode.
This only needs to be done one time, and then momentary mode can use the turbo level.
Turbo is also available in sort of a momentary fashion by doing a double click while on.
About the lantern though, it already has its ceiling levels set as high as they can go, by default. So this isn’t an issue on the lantern unless the user manually lowers the ceiling level(s).
That may be, but unless they suddenly push codes for all the slots up to 3000 I’m not going to be able to order all of them in the next few days.
I have little reason to order a stack of lanterns to sit on them for almost a year until next Christmas when future production runs will likely fix the USB-C charging issues and other minor problems. We’ve already seen they can be bought for the group buy price (or better) outside of the group buy, so I will likely forgo all my extra group buy slots unless something changes and revisit buying LT1’s as gifts in the fall of 2020.
