It is better to focus on things from a depolarized perspective. You must be obtaining tangible benefits from what you call a habit.
But not all habits render benefits (if any), drug addictions being one them. This is because any possible benefits are linked to the detrimental presence of the drug in your body, which is linked to the light-force draining presence of negative entities attached to your subtle bodies. Thus, only via mind-reprogramming it is possible to bring back the benefits without harm.
The cells are good, pretty sure some decent standard 2C discharge high capacity cell from some OEM.
Getting good cells isn't the problem, the problem lies in the dubious nature of the rewraps, often with false advertising, and the corresponding lack of information concerning what we are really buying. This is wrong and it has my Seal of Disapproval®.
I would also add single cells might perform good, but how they would work in series? Quality should be uniform, but we don’t know nothing about it nor we can be certain what we’ll get next time or even in the same batch.
Your consistency concerns are understandable ledoman. From the standpoint of a battery pack builder, if cell consistency can't be guaranteed all units need to be carefully tested and binned. This takes time and effort which is money. I obtained channel measurement correction indexes for my Lii-500, just in case I were to need it for such role.
Sigh. Thanks for the warning in the original post. I came across these “30Q” cells in Ali and actually thought, briefly, that they might be a good deal.
I'd like to make a brief comment here. I often see people complaining that this is fraud and blah blah blah. Well, from their perspective what they're doing is 0K, and to some point it is because they're not selling cells under a trademark they don't own, technically their trademark is LiitoKala. On a shadier note they use big brand cell model numbers, and on an even more shady note “they” wrap their cells making 'em look like cells from the big brands. I do not endorse this but it has its reasons, one of them is they're serving a market of uninformed people who may be thinking they're buying the real deal, and also a market of consumers who don't give a flunk. Bad and bad, and to cap it all the lack of information concerning the industrial products they're selling under the wraps. And it's not only LiitoKala, you know.
For now the best you can do is deal with it, spread knowledge and raise the vibration of those who don't know. The big brands don't give (much of) a flunk about this, their stuff is cut and dried.
Chinese cells can be bought with non or a lot less spurious wraps, see for example this Colaier G35 cells advertisement (looks like some sort of high capacity cell from BAK).
Wellp, that was brief. I could over-analyze the situation, even start blaming here and there but no point, nothing good would come out. Let's en-lighten people, creating for the better.
Helo all
I read few pages where not to buy batteries…Has anyone some shop name from EU or Ali, where I will recieve genuine Panasonic for reasonable price.
I recieved fake from Banggood, fastech, liitokala, varicore,… last “NCR18650B 3400mAh” protected from varicore (ali), was less than 3000mAh, the protection cut off at 2V.
Where to buy???
Fellows, please don't delete your posts right after publishing them unless you absolutely don't want to say a thing. I mean, edit and change whatever in them. When you delete a post and create another right after, the thread answer notification becomes invalid.
I wondered when I saw the Colaier G35 cells advertisement if that was as good a deal as it appeared. Thanks for commenting on it.
Hm, Colaier also sells the Lii-202 charger for several dollars more than other places that have it marketed under their own brand. Hmmm.
Wow! :facepalm: He built an e-bike battery pack where he is using a thin wire to carry all the current from each battery stage (up to 30A or more). Creepy! Hope he is fine, really. I would have used ≈5x AWG20 wires or 5x (2 × 0.25) mm² solder wick patches for that same requirement, better safe than sorry.
Looking for a cheap single-cell charger to include with flashlight gifts. Had my eye on the Liitokala Lii-100, but can’t find it from a US supplier.
Does somebody know where to get it in time for Xmas?
Or can you suggest another?
Must have
Less than ten bucks, preferably a lot less.
Single-cell, multi-size.
Lithium or NiMH Charging (I think NiMH capability is important when giving to muggles, a bit of idiot-proofing.)
A charge percentage indicator, not just a red-green light. 25-50-75 percent.
Power bank is a plus, not required.
USB, no wall wart needed.
Deliverable in less than two weeks.
