Sofirn will make sure every single person get code for one unit. Then go back to rescan the list and send new codes for those who want more than 1 lantern.
Not dismissing his work, but holy mother of god, all that for a cable? But itās cool, go for it. Itās a fantastic lantern,waited almost 4 yrs for it. Already used for 4 days at deer hunting camp, and it works and charges flawlessly.
I responded with a request for code with batteries the second I got my original code. I didnāt receive a response and by the time I tried to use the original code it had expired. I think there are probably many of us in the same boat that havenāt been able to order off the initial batch.
I just checked PMās today and got a message from Sofirn with a code. Responded and asked for a code for the LT1 and batteries. They responded in a couple hours and I got the light ordered.
Itās not about the cable. Itās about recognizing that āproperā USB-C power bricks and cables are becoming more and more common and having to keep an older style cable and charger on hand will slowly become more and more annoying. Is the mod annoying? Definitely. Is it worth the effort for some of us? Defintely.
Iām glad to read the rest of your post though. Hearing unbiased reports of how well the lantern works just makes me want my order numbers to come up faster. :+1:
Colors are not confirmed. With that said, some of the discussed colors are almost certain to appear as Sofirn has expressed interest, but it might not happen for a number of months depending upon how well Sofirn can manufacture LT1ās and how many they continue to sell after the group buy is fulfilled. Right now Iām sure that they are focused on producing black LT1ās in relatively large batches in order to satisfy the existing demand (i.e. us).
Iād accept the black lantern if you want one right now, but you are of course free to wait until colors appear sometime next year (if they appear) as Iām sure that there will be tons of sales and coupons for the LT1 over the next year or more.
The above are my impressions and opinions from following this thread, so take them with a grain of salt. Any or all of it could be wrong.
The most difficult part of this this mod is that is small.
Smaller than what most of the hobbyist are used to, but not undoable
If you deal with anything but shady backyard electronics where your āsolderingā skills came from sweating pipes at your uncleās house or splicing wires in your can chances are that you will have something that will work to do it.
You know what I find hilarious is that some (including you) went through the effort to line up your bail with the switch.
Donāt yuck someone else yum just because you donāt like it.
I knew that usb c power delivery was gaining ground fast vs older charge protocols, but to a point where someone would struggle getting access to a regular usb A port? I wouldnāt thought this were going to happen so soon, not in 5 years at least.
AFAIK this lantern will charge with every single charger that is not power delivery exclusive and provides any voltage (within the input range) by default, no matter the cable. By default I mean if you connect a USB C meter to it it will read 5V. Almost all of the flashlights with dumb input works this way (no coding chip just a DC-DC converter). I havenāt received the code yet to test myself so I could be wrong.
USB-C is a physical spec. It is effectively defined by the connector and the fact that the hardware (connector and cable) can support at least 3A of current at minimum. PD is just ones and zeros flying about.
You can have USB-C chargers that are not PD. And it gets more confusing from there.
USB-C power meter need some power to run itself to it so it terminates the cable properly to get 5V. Same thing as USB A to C.
On USB-C there are no 5V on the VBUS until there is a pull down on the CC lines.
For me it is mostly a convenience thing. My tech replacement schedule worked out in such a way vast majority of things are USB C now. Phone, headphones, entertainment. So now if I go anywhere all I need is one charger and one cable to rule them all. Including the LT1
So actually, at least for me, finding USB-C chargers and C-to-C cables are easier to find as compared to A to C cables.
