*BLF LT1 Lantern Project) (updated Nov,17,2020)
I too would like to know if the colored varients will be included in the group buy. Would Sofirn be able to comment on this? I’m signed up for two of them and would prefer to wait for a colored version (fingers crossed - orange!) to purchase my second.
Thank you too Sofirn for bringing this project to life and making it a reality! :+1: Sofirn is doing an amazing job on building the BLF LT1, added with the thanks to all the amazing LT1 team, and a thanks to all the great support from BLF and the members. It has been a honor & privilege to work on, test, develop, and help design a great area lantern for a lacking market. :beer:
We are hoping that will be. :+1:
Note: I am not affiliated with Sofirn and have no influence or special information.
People on the group buy list are under no obligation to purchase anything and your position isn’t transferable. We appreciate your offer to let someone else take your current place in line, but it’s too complicated to then keep track of your “new” place as the group buy list is permanently fixed.
I recommend that you keep your current “position” for yourself and simply don’t use your code until you have the money. Yes, your existing code will expire before January, but I suspect that Sofirn would be willing to renew your code a month from now if you PM them after you’ve got the finances in order.
You should ask Sofirn about your situation in a PM and perhaps request a new code a month from now if yours remains unused. There will surely be some reasonable time limit, especially after the second pass through the list is completed, as Sofirn will understandably want to wrap up this process and move on to something else.
@All: If I’ve given bad advice or said something incorrect or misleading here, please correct me and I will edit the post accordingly.
sounds like good advice, thanks for taking the time to post this. Of course, Sofirn is the final authority here.
I’m interested if anyone drops out if the GB list. The LT1 looks great!
A lets not debate the tops of cells perspective.
From the beginning, I believe buyers were told that flat top batteries will not work reliably. Or at all for many cells.
The horror that has spread “requiring” users to throw away the “faulty” (no nipple) cells. I would think there are a lot of users that have the specified cells for the Q8 and LT1 designs (i.e., not flat on top). They are following instructions.
One should harken back to the Q8. You know, that big round black thing (pending possibilities of colored shells) that holds up the lantern. And the electrical paths. And the cells. Which all seem to work pretty well. The power interfaces are essentially identical.
I believe (not going back and re-reading everything) that from the beginning early design of the Q8 project and through the LT1 project, we have repeatedly told potential buyers about not using flat top Li cells. A lot. The reason is quite clear; and outside the design. These cells are neither hugely expensive (they are regular old common cells) and not difficult to find from vendors that add the button and maybe the safety fuse in the cell. Laptop cells are also popular, but likely weak. There are probably more flat tops on the market than any other form; but they are only a step away from solder bumps or vendor posts.
Could we all quit bitching about the tops of cells, start following the design specifications, and move on. I see no reason for supporting some way to make flat top cells work (except in a few cells claiming to mostly be OK). The only responsibility of the team and other members, it to tell the non-button people that the specified battery requirement was included in two very significant builds. It is their problem to work around using the wrong cells; and not a design problem.
The designs are good; and safe.
One short addition: the cell wrappers for sale. I would not generally contest someone helping and maybe picking up a few bucks in the process. But I have a real concern about people (not just muggles) being confused by the wrappers and alternating the direction of the cells. I would not put them on my eventually available cells. Alternating battery orientation is a common thing with batteries. I would not trust my possible users with cells with those markings.
So wjat happen with ordering from eBay?
The eBay option method was originally to make an offer on the lantern using the GB price and placing your BLF user ID in a note. Maybe include the code you received as well. Then Sofirn should adjust the price, you pay and then they ship. But I can’t find the LT1 on eBay at present. Send Sofirn a PM and ask what to do.
A note to users of the LT1 that want maximum run time - use the lantern either on full WW or NW. Tint mixes increase the current draw by about 15-20% over either end of the tint range. I’ve not tried to characterize this, I just noted some observations in this post.
https://www.amazon.de/gp/product/B07YS6W4CJ
LT1 Mit Akku = LT1 With Cells
LT1 Ohne Akku - LT1 Without Cells
Both options are still there 05.00 GMT
Hi, would you mind ordering one piece this time? You can buy the other lantern when it’s available to purchase multiple units one time.
Colored version need to wait. available time is not confirmed yet. sofirn is waiting for the anodizing factory’s reply.
Thanks for the update!
can i use my code for a green lantern when it will be available ?
Hi, could someone tell me what the trimmer on the back of the board actually does? Thanks!
Edit: Apparently nothing, as some people removed it without effects.
Nevermind.
And will Batch 3 (with the USB C function) be included in the group buy? Thanks!
Code received in PM from Sofirn on Nov 26th … Code entered on Amazon US site for LT1 lantern without batteries, quantity one, … on the Amazon checkout page … ‘the code that you entered is not valid’.
I have used cut and paste directly from the PM and also tried manually typing the code. I matched case (upper) or not (lower), and included the dashes or not. Nothing works.
Pattern of the supplied code is AAAA-AA9AAA-AAAAAA … Alpha’s, dashes, and Numerics only.
This is my first LT1 order and I’m not attempting to buy multiple items with repeated orders either. I won’t complete the order until I can apply a code to lower the price.
Sofirn has been informed by PM and I have asked that they look into this situation further.
Anyone have an idea about what I’m missing? …. Is anyone else having a problem with the first supplied code?
My code worked flawlessly, but I know of another German who had to get in contact with sofirn to sort something out.
I guess that they are very busy right now, and they will sort everything out eventually, but maybe not within seconds.
So I guess everyone having problems should clear that out with sofirn via PM.
Maybe we should have another thread for order-related issues, and keep this one to discuss technology?
This other LT1 purchase topic could be a place for for those maybe: BLF Lantern Purchase/Followup Information - Group Buy list is Closed!!!!
