RD new greatest power supply RD6006 DC power supply coming soon
could you add our products link on the video :smiling_imp: :sunglasses: :smiley: ?
https://www.aliexpress.com/item/4000282551930.html
Can two RD6006 be used in parallel to achieve 12A?
no , it can’t , we don’t allow that , output must be isolated…
RD6006 power supply feedback:
as always, everything is fine, the packaging is beautiful
RD6006 customer feedback:
awesome made my month
RD6006 feedback from EEVblog
product link: https://www.aliexpress.com/item/4000282551930.html
What’s the advantage of this over a much more powerful DPS5020?
1.you can see the screen is bigger, we change the screen from 1.44 inch to 2.4 inch
2.the settings will be much easier because we add a keypad, if you want to set output value, you just need to spend a few seconds
3.add battery charging terminal, for more detailed information, you can see the videos on the youtube, we uploaded a lot
4.PC software has been changed a lot, now it is not only a data recorder, you can upload firmware for new function and use calibration function
as for other functions, it takes much time to introduce, you can check the product detail page or watch the videos
detail page:70.89€ 20% OFF|Rd rd6006 rd6006w usb wifi dc dc spannungs strom abwärts strom versorgungs modul buck einstellbarer wandler 60v 6a batterie laden|Multimeter| - AliExpress
youtube channel:https://www.youtube.com/channel/UCy73jJ5-ZqhPzT7wJ6KTIaw?view_as=subscriber
set RD series and DPS series on the same panel
RD6006 link:https://www.aliexpress.com/item/4000282551930.html
The module arrived well packed. The size was smaller than imagined. The module was tested, all the main features and characteristics are in place. Special thanks to the developers of this device for removable fuses
RD6006 feedback:
Everything is super. Thanks. Packaging at altitude. Delivery to Domodedovo 20 days.
RD6006+S06A case feedback:
I am very satisfied with the items, both.(waiting for your assembly)
[Perfect quality items. Great seller. Everything like in a description.]
[He came to Moscow in 3 weeks. The packaging is great. Initial launch successful. I did not complete the full test.]
[Great body! There are no dents, which is not surprising - the body in the foam is completely and wrapped in 3 layers of bumps. I recommend the seller. We are waiting for the last device - the 60 volt switching power supply itself]
https://es.aliexpress.com/item/4000282551930.html
if you have any questions about RD6006, you can search RD6006 on youtube, we make many instruction videos to show the operation
Very nice box and easy to assemble. Just follow the instructions.
I make a video list on the RD6006 detailed page to show the operation and solutions when meet problem
RD6006 detailed page:https://www.aliexpress.com/item/4000282551930.html
video list:https://www.youtube.com/watch?v=irTbqfqtgU0&list=PLNcr2Rj_07PEVpDagutCmxWkREnAJwPUt
show me your workbench:)
picture from customer
RD6006 feedback
Very roomy body. For the cooling system is a separate plus. By the way, the fan changes the rotation speed depending on the heating. The default is off. Look for a detailed review on the КИТАЙ В ПОМОЩЬ YouTube channel.
