Your conclusion is wrong, you don’t need anywhere close to such low absolute PWM levels to get the FET reach Moonlight
the resolution is needed and the threshold depends on components used, another FET will result in more or less absolute PWM duty cycle needed
I have seen this on my scope before you see the nice PWM signal on an MCU output without load
then signal gets some slow voltage rise on very short timings
and the Output on the LED is also another story as after you charged the gate the FET needs also some time to get conductive
if you look on our AMC with 47Ohm gate resistor drivers you will see at PWM level of 1/255 no output or almost none
depending on how the voltages and temperature this drifts
on 2/255 you get fairly low output
at 20kHz and 1/255 you look at 0.2us pulse with
problem here is the Gate resistance is about 50 Ohms at like 3.7V
now you need to charge up the gate charge is about 10nC of a regular full sized LFPAK56 MOSFET to get it conductive (this depends on the gate threshold voltage)
so we got
200ns time at 1/255
10nAs
50 Ohms gate resistance
Calculations:
Gate current is 3.7/50=75mA
the Attiny can only deliver about 25-30mA
0,030A*200ns=6nAs (in reality its probably less because gate resistance, other capacitance’s and so on)
Fact is a usual driver does not light up when the main FET is on 1/255 cycle
you would need increased resolution between 1 and 2/255 PWM cycle, this also depends much on the
an ideal Gate driver of switching drivers usually can push 2A or more to get very short switching delay and times
You are totally right Lexel. I’ve forgot we are not living in perfect world where everything is so simple. Thank you for your input. I would like to learn more of electronics, so I’ve done same research and it look there are much more factors than I thought. FET behavior will also change with temperature change. As I understood the best FET would be the one with smallest gate capacity, but I suspect this is just a part of story.
Anyway maybe there is a way to stabilize FET output with some constant PWM adjustment?
QG<30nC at 4.5V (the gate charge gets bigger with more voltage, but only a part is needed to get above the threshold and the FET conductive)
RDSON 1-4mOhm
I’ve done some research and I think you should focus on the shortest raise time and fall time than Qg and RDSon. This probably telling you how fast you can switch FET with PWM.
Not sure how much turn on and turn off time matter.
Also lowest Vgs th better.
Power dissipation probably is also parameter you would take a look at.
Seams that FETs that Lexel already pointed are one of best we can have.
Again if you don’t have a real FET gate driver that can deliver like 1-2A with about 2-3Ohms driver resistance you will never see such short raise/fall times
the gate charge is the most limiting source when driving with the little current from an Attiny MCU
Higher RDSon MOSFETs with less max current capability have smaller chip area reducing the gate charge and speed up the switching
A MOSFET has always switching and conduction losses, at our low frequency of about 20kHz the conductive losses play the major role
If you want to increase the resolution you can reduce the Moonlight PWM frequency by factor 10 to about 2kHz still having a bit more than 10 bits resolution (but you need to implement that into a firmware)
you can create a Gate driver using two small SOT532 MOSFETs (crucial here is low RDSon and enough peak current, so they don’t get blown remember most big switching MOSFETs have like 1Ohm Gate resistance making the worst case 4A peak current while charging the gate)
one N channel on the MCU and one P-channel driving the MOSFET
Then you get very fast switching time as the gate and now you need to focus on more resolution of the PWM source
Then you have then significantly increased the current ringing problem and may need additional MCU voltage stabilization adding a 2. low pass filter (most new designs have 4.7Ohm plus 10uF behind it to eliminate the spikes that can reset the MCU)
Designed my own FET+1 driver for D10 headlamp. Circuit identical to D4, only indicator led and cap on output to reduce moon a little. I’ll go for Si4866BDY. Found it for 12 cents
It would be a very efficient way but also quite costly and complex….Really the efficiency difference wouldn’t be all that big so return of investment would be fairly low.
I’d love to see it though.
this FET has no advantages electrically over the other mainly used MOSFETs, it is only cheap
high input capacitance,
Gate charge,
relative high RDSon,
bad thermal conduction to PCB
I bought recently pretty good FETs for 1 Cent price bug I can sell them here cheap
Is there a schematic available that works with Bistro? I’m trying to figure out how it works, such as if a capacitor keeps a residual charge during a half press, etc. And how the MCU remembers the last mode after remaining off for a while.
You will have to dig through the archives to find all the details on that.
But on a basic level, the OTC cap drains when power is cut and when the MCU turns back on it reads the remaining voltage. Based on that remaining voltage it decides if it is a half press or full press.
The downside to this is that it can be inconsistent, which is why a better option has been desired for some time. The idea option is to use a larger cap to keep the MCU powered for a few seconds after the light is turned off so it can measure the exact length of the button press.
A lot of the base design stuff like that was many years ago, we have just refined the ideas since then. Not sure what to search for, off time cap and OTC are ok but honestly since the design has evolved many times over the years, not sure you will find an all inclusive rundown.
The design we are using now is fairly simple to figure out though, the OTC cap is what measures the off time like I said above and the other pins are basic inputs and outputs for the different channels.
For the firmware side of things, that is another all game, it is open source if that is your thing but toykeeper and TomE are the ones that have made this work.
