The sensor is inside the MCU. I don’t think all Atmels fail 8n MF01 mini and work fine in other flashlights. You can replace the MCU and got the same effect. So heat sinking is the solution or you need to redesign and remake driver pcb.
What other model shares all of the mini’s electrical components, but experiences no premature throttling?
What inadequate heat sinking theory explains DECREASED throttling during CONSECUTIVE max ramps, while temps INCREASE?
Recap: As the light gets hotter, it stays maxed longer … Maybe because the throttling is not heat-related.
If anyone has 2 batteries, with confirmed identical output, then they could test electrical throttling by heating the light with one battery through repeated max ramps, until it stays maxed significantly longer than the initial cycle. Next, swap that battery with the freshly charged one into the hot light and retest max ramping. If the light prematurely throttles with the fresh battery, then the experiment points to electrical throttling, not thermal?
the AMCs have also a thermal throttling, so they can’t get too hot, maybe that’s also a cause of the thermal problem
The copper/brass insert the forum member offers with technical drawings and CAD model available to me and I sent it to Mateminco with the request to update the lights
I already talked with them in the design process about proper heat sinking which got ignored in final builds,
the light was sold pretty quick to counter Fireflies 7x LED light without proper prototype sent for test/review and improvements getting to production model
I kind of hate the fact they changed your design and replaced that mosfet, inductor and diode and messed up that voltage measurement. “Value engineering” is reaching new extremes in china, they replace components worth few cents for ones worth few cents less not caring what the consequences will be… They often manufacture so many thing at the bare minimum requirements for functionality. Sad thing is it prevents them from gaining “brand loyalty”, which could in the end earn them much more. I asked mateminco for how much they would sell me a spare driver (for experimenting, flashing etc) they told me 33.5$/piece. When I asked them what the wholesale price is for 15 flashlights, they also told me 33.5$/piece (i was considering buying 15 flashlights as business gifts to emplyees). They literaly sell driver board at the same price as full assembled flashlights. Not very modding comunity friendly…
Samsung 40T starts off barely higher for only a tiny bit, then the Molicel beats it by a pinch the rest of the way and can go higher amps without failing (future proof).
It would be better to write him a message directly if you need answear fast. But very likely he will have to ask them, so you might as well ask them yourself.
OK If I get the news, I will let you know.
I contacted Mateminko and asked if they plan to put this copper washer on new lights (new batch).
I received an answer from them:“We are thinking about it now”
And then I wrote to them:“After you make the final decision, please let me know.”
Well, Lexel has already talked to Mateminco while the early development and prototype testing phase of the MT07 about this topic. It seems like they don’t react on this.
Actual Lexel has already sent the technical drawing and the 3D-CAD model with the results of the latest version to Mateminco. We will see how they will decide on this.
If they want to realize such an update, the manufacturing costs will be higher and most likely they will have to set the price higher for the light.
And then they will ask themselves whether it can generate more sales with such an update then before. I doubt it a bit because most customers/buyers don’t even realize the problem or pay attention to it.
I wished they’d rather implemented a aluminium washer to address this issue instead of going for fan-service in the form of USB-C charging which also has a very negative impact on the waterproofing.
They might in the future or in next larger batches. Who knows. They might implement it in future light designs of other models if people demand it enough. The truth is people demanded USB charging. To a lot of customers it provides many more pros than cons. You can still get some waterproofing against splash and rain while not having to pack separate charger if you travel with the light. It also increases the “giftability” of the light to people who dont need to learn so many things about LiPos (just basics) and it also increases their possible customer base. They can sell combo packs with cells (which they do) to people who wouldnt buy them if they didnt have charges implemented.
