After writing yesterday's post i started to think about several modifications/improvements in the way i might use the wood block but still have some unanswered question (mainly about the on/off switch and battery compartment) so i decided to work on the driver instead.
Take a length of enameled copper wire, the smallest toroid ferrite core you can get, one of these very nice 5mm high CRI 3400K led rngwn is selling plus a (small) npn transistor (PMBT2222 here) and a (even smaller) 1k resistor. Don't forget your schematic !
Assemble the parts on a piece of prototype PCB and, after verifying that everything is ok, switch the power on.
The dinner was short but i had to do a lot of measurment so i am back only now !
I know that's a lot of numbers but i'm still searching a way to display them in a clear and nice graph (anyone knows how to have several secondary axis on a graph with Libreoffice Calc ?)
At first i measured a led alone, varying the curent and measuring the led voltage and light output and calculating the led efficiency :
Supply curent
(mA)
Supply Voltage (V)
Supply Power (mW)
Light output (lm)
Led Efficiency
(lm/W)
1,0
2,59
2,7
0,3
129
2,0
2,62
5,3
0,7
128
3,0
2,64
7,9
1,0
126
4,1
2,66
10,8
1,3
125
5,0
2,68
13,4
1,6
123
6,0
2,69
16,2
2,0
122
8,0
2,72
21,8
2,6
119
10,0
2,74
27,5
3,2
116
12,0
2,76
33,1
3,8
114
15,0
2,79
42,0
4,6
111
20,0
2,84
56,8
6,0
106
25,0
2,88
72,0
7,3
102
Then i did the same kind of measurements on the driver + led and used the (roughly interpolated) led efficiency calculated in the previous table in order to obtain the driver efficiency :
Supply Voltage (V)
Supply curent
(mA)
Supply Power (mW)
Light output (lm)
Total Efficiency
(lm/W)
Led Efficiency
(lm/W)
Driver Efficiency
0,60
10,1
6,1
0,4
65
128
51
0,70
15,6
10,9
0,7
67
128
52
0,80
22,7
18,2
1,2
69
125
55
0,90
25,5
22,9
1,6
68
122
55
1,00
27,9
27,9
1,9
67
122
55
1,10
29,8
32,7
2,2
66
120
55
1,20
31,4
37,7
2,5
65
119
55
1,30
32,7
42,5
2,7
64
118
54
1,40
33,7
47,1
3,0
64
117
54
1,50
34,8
52,4
3,3
63
116
54
1,60
38,1
60,8
3,8
63
114
55
The efficiency is not too bad for a "wet finger" type of design but the light output is a bit low for my taste.
For comparison here are a few values that i measured on a warm white Sofirn C01 :
Supply Voltage (V)
Supply curent
(mA)
Supply Power (mW)
Light output
(lm)
Total Efficiency
(lm/W)
1.0
38
38
3.0
80
1,5
54
81
5,5
68
So now i have two options :
1) Try to optimize the joule thief driver for more output (find a better transistor, test various parameter changes for the transformer)
2) Use a more conventional (and predictable) regulated boost driver
Well it's 03:15 so the only real option right now is to go to bed ...
Edit : corrected a few errors in the driver + led table
So i was balancing between trying to improve the joule thief or going for something more conventional ... and i eventually decided to keep the JT for this prototype.
Several, reasons :
it's cool ;)
i like to tinker with new things and i don't know that type of converter very much
i usually prefer a regulated output on my flashlights but the "less volts, less output" works well for a small vampyr light
there is plenty of time for improvements and tests before the end of the contest and i'll still be able to change my mind later and go with an other driver if i feel like it.
While i intent to do a lot of measurements on the driver for each modification i have to improve my test setup !
One thing i went through friday evening while doing the first tests set was that it was teddious to read the display of the two multimeters and the luxmeter because they were not leaning at the same angle so i improvised a "deluxe foldable measuring stand"
Ok let's work now !
I expected to be able to use a breadboard with traditional "through hole" component for easier components changes but the result was not very good (unstable measurements caused by bad connections) so i had to ruin the nice prototype with a lot of soldering/desoldering.
An other problem i met was i had no good way to fasten the protype to my integration sphere which caused some variations in the measured light output so i eventually soldered the led on his own board with a long wire running from the driver and taped the led board to the sphere so i was able to work on the driver without disturbing the led position.
Eventually i was able to obtain stable and repeatable readings and went through many tests series
The following picture shows the final setup :
Not much else to show for now as i tested several transformer configurations along with several resistor value during the weekend but this is still a work in progress and i don't want to frighten everyone whith pages full of numbers !
Just a quick update as i don't have anything new to show but a lot of boring tables full of numbers, a poor abused prototype and some weird 3 or 4 legged toroids
I am still working (maybe 20 hours total now) on the joule thief driver, trying to obtain the right tradeoff between output and efficiency, and i feel that i have gone as far as i could with the PMBT2222 so i have ordered a few other references that i expect to be better in that application (mainly higher gain and lower Vce-sat) and hope to receive them before the weekend !
Yesterday i received a few tansistors so i was able to do some (well ... a lot !) more tests in the evening/night.
The driver is not totally perfect but considering the very simple schematic i am pretty happy with the result and consider that i am done with that part !
More on the driver later but today i wanted to work on the "case".
Hand tools :
I cleaned and sanded the aluminum profile and wood block, drilled the led hole and carved the battery holder then assembled the whole thing.
Everything is fitting nicely
No screw required because the wood fits tightly in the aluminum profile
To do list :
find a sliding switch and mount it on the side of the aluminum profile as the one on the picture is a small pcb switch with no mounting holes
find some thin spring brass plates for the battery holder (for now the wires are soldered directly on the battery)
find a good looking piece of hard wood as this one is too soft an easily scratched as can be seen of the last picture
Random picture from internet of the Wonder mini that inspired this small build :
Wow! I haven’t seen a drill like that for a very long time, let alone use one to drill a hole. I am so spoiled by power tools, especially cordless ones.
As i promised yesterday here are some details about the joule thief driver.
The schematic is still the same with an added X7R 10uF decoupling capacitor at the input. I am not sure if it's really required here but i am used to always have at least some decoupling and it might help when the cell internal resistance increase.
My goal for this driver was :
output at least 5 lm at 1.5V
still about 3 lm at 1.0V
at least 1 lm down to 0.7V
overall efficiency better than 65 lm/W at maximum output, going higher for lower output
These goals were copied from the Sofirn C01 3200K which was my reference while designing this little light. The C01 driver use an integrated circuit with output regulation and the single transistor JT can't really compete with that but i tried my best and here are the results :
Light output (lm) vs input voltage (V) curve :
Efficiency (lm/W) vs light output (lm) curve :
The green curves (JT 1) are from the first JT prorotype.
The orange curves (JT 2) are from the final JT prorotype.
The blue curves (C01) is from the Sofirn C01 3200K which was my reference while designing this little light.
As you can see, working on the JT allowed me to increase both of the light output and efficiency compared to the first prototype but there is a limit after which i wasn't able to increase efficiency without decreasing light output or vice-versa so i choose to keep the output.
Conclusion :
As can be seen on the curves the ouptut light goals are totally met and while i would have liked the efficiency to be a bit more on par with the C01 i am still very happy with the (about) 10% difference considering the very simple schematic !
While the informations that could be found online about the joule thief are often contradictory and for the less inaccurate it was difficult to do any realistic calculation or simulation and that was mainly a matter of doing a lot of tests (measuring curent consumed at the input and light output vs input voltage) while varying tore type, winding configuration, base resistor and transistor type, one parameter after the other and see how it affects the results.
An other thing was that i had several small tores laying around but no information about what they are so i had to test them all.
Of course i have tested a limited number of components that i already had at hand or that were easiliy available so it might be possible to increase efficiency with other tore or transistor types … and more time spent
Back to the "case" (i hope i haven't lost you all while working on the driver) !
As i said at the begining, the case was just a quick and durty prototype, so now that i know where i want to go i'll try to do something nicer !
I am not sure if i told you already but i like to "do with what i have at hand" ;) as much as possible so i went rummaging through some "may be usefull" boxes (my daughter call them "garbage" ) and i found a piece of old wood.
Doesn't look very good at first :
But i know this is a piece of an old floorboard and it must be oak or maybe chesnut so it can't be that bad !
The other side looks better so after some cleaning i start to saw it with my hand saw :
The piece on the right was supposed to be the one, but as some may have noticed already, there's a knot in the midle that will prevent me to carve it as i want to (the other side shows a void around the knot).
Then i had to saw an other piece but the wood is VERY hard and difficult to saw with the hand saw i have at home so today i took it at work and used and old bandsaw we have in the workshop.
While i was there i sanded it with the belt grinder and drilled a lot of holes with the bench drill :
Finaly i took it back home and this evening i removed the holes (or added some bigger ones as you prefer) with my chisel :
Note : I am far from beeing a wood expert but this wood seems too hard ! I don't know how to explain it exactly but sometimes it feels more like it is chipping like hard stone than beeing cut. Could it be because the floor it comes from was just in front of a fire place (i remember that) and it was slowly backed day after day for many years ?
Well ... i asked for hard wood and that's what i got ! ;) At least, seeing the results of my first tests, it can be sanded down to a very smooth surface !
I had similar issues with drilling & shaping indian rosewood, it seemed to chip out in bits, quite hard wood but sands up to a nice finish.
That was my first experience with careful woodworking really.
I imagine ebony & such other hardwoods would be worse to work with.
Best to tool it slow and avoid undue pressures as cracking is a problem too, especially on dried out older wood.
With hard woods sharp tools are the key. If you plan on doing much hand cutting of hard woods the Japanese style of handsaws are excellent. Good ones are not cheap but they can make wonderful precise cuts. They cut on the pull stroke which allows the use of thinner blades. Takes some getting used to if one is used to using western cut-on-the-push-stroke saws.
