Following. 47 has it so close with their QK2A mkiii but then missed entirely.
The Pelican 2360 I just picked up is pretty solid for a working light. Still lacks tailcap lockout but the switch is a good balance between low profile and easy to use. Just wish I could swap a SST-20 in place of the XPG2 without voiding its lifetime warranty. Some of these “professional” type brands really need to jump on the CRI band wagon! (Although its definitely CW it is a very pleasant beam, throwy with good spill and cool white but not angry blue)
I’m trying to come up with the smallest tail-clicky 14500/AA light I can (and AAA too for that matter) … Besides my DQG Slim. I want to hot-rod it, but if it’s not small enough it just feels pointless compared to 18650.
But, for stock, I love the DQG Slim 1/2AA plus extension tube. Throw a 1000 mAh 14500 in there for unmatched capacity, or use eneloops, or Alkaleaks in a pinch.
Looks like Soda Can lights run 1100-1500 lumens. Manker T02 (2xAA side by side) claims 1500.
The Acebeam H40 claims 1050 lumens, and is $30 at Illumn. There’s probably a discount code, now that it is back to full price. It’s a right angle light though.
I’d like to see some independent tests of that Manker. IMO, they over-state their lumens. My T01 (1xAA) has nowhere near the output they claim, and it’s not regulated on max either.
Yes, single AA light…
Great lights, thank you all.
I’m looking for a design similar to maybe the Manker T01 but less bulkier one … I like the Wuben E05 too.
As for the batteries, after all these years and they’re still stuck at 2500mAh? for God’s sake, why?!.. LOL
are there any higher mAhs available with low self discharge ?
You could try the Zebralight SC53w (330 lumens, $57), or the Zebralight SC52 (300 lumens, $49). You won’t find a more pocket-friendly AA light unless you go to a twist-on switch. The advantage of the SC52 is that it can also use a 14500 for 500 lumen output. I don’t usually run mine that way, but it’s fun when I do.
No. There’s not much demand for newer NiMH tech nowadays, so I don’t think they’re doing much to improve it. There’s small incremental improvements with Eneloop over the past several years, but nothing significant. Just like you don’t see much improvement with alkaline batteries… they’re good-enough for their intended purpose (which is ruining electronics by leaking).
There was a version of the TN4A with an XP-L HI. Perhaps that is what you are referring to. With the XP-L and the OP reflector my TN4A has more flood and more throw than my SC31B with the SST20. My C8 silver with the XP-L HI SMO out throws both of them. The hot spot on that is so bright that I can understand your comment about it not being a good leash walking light although I did that for quite some time and didn’t realize how bad it was.
OTOH, I think that these two examples of single 18650 lights and the TN4A AA are fairly similar with the TN4A having the widest beam and the C8 having the farthest throw. Size and weight are biggest things that make it different. Of course what I like are the UI and the tint and something similar can be found in many different lights.
Yes, I have the XP-L HI version. I don’t use it anymore, since lights of similar size (like the Astrolux C8) out-throw it and are lighter. But for a AA light, it does throw very well.
I used the engineering mode to set it to max output without any step-down. But, yes, I also set up the regular modes so that the brightest is at max output. It is a bright light, and does have impressive throw for such a small 1xAA light. It’s just not as bright as what Manker claims. They claim 500 lumens. IIRC, I got almost 400, but only with a fully-charged Eneloop. It drops output as the battery declines, and it does that fairly quickly since NiMH voltage curves have a pretty steep drop at the beginning.
Oh, and their claim of 900 lumens using a 14500 cell is waaaaay out of reality. It’s really not that much brighter than with NiMH.
I prefer the regulated boost driver of lights like the Zebralight SC5. It has higher output (still not quite 500 lumens, though perhaps the MkII version does), but it will maintain that until the battery is almost dead.
But, if you’re looking for a 1xAA pocket-thrower, the Manker T01 does a good job of that.
