L shaped zoomie? I don’t recall seeing one before…
http://www.aliexpress.com/item/33007999176.html
Another few:
http://www.aliexpress.com/item/4000217410512.html
http://www.aliexpress.com/item/32887626377.html
This one is 26650:
http://www.aliexpress.com/item/33003661661.html
Anyone fancy a lantern?
Note that it doesn’t seem to be yet another “lantern” which has merely translucent bezel that turns otherwise wasted light from the main LED to actively-disturbing side spill. It seems to have a separate set of LEDs for side light.
http://www.aliexpress.com/item/32760825307.html
18650 variant of SK58?
http://www.aliexpress.com/item/2050936588.html
Diving zoomie?
http://www.aliexpress.com/item/4000070058911.html
Zoomie with a side light?
http://www.aliexpress.com/item/32824807511.html
Skywolfeye has shown a number of compact zoomies lately…there’s 18650 variant (T123) as well, though larger that I could hope for:
http://www.aliexpress.com/item/32972584714.html
Yet another 18650 with side switch and charging:
http://www.aliexpress.com/item/33048541527.html
Larger 26650 light with side switch and charging:
http://www.aliexpress.com/item/4000351584884.html
Is anyone short of 18650 zoomies with side switch and micro USB?
http://www.aliexpress.com/item/4000250899313.html
What’s up with this lens?
http://www.aliexpress.com/item/4000057724328.html
A different zoomie with side light?
http://www.aliexpress.com/item/32975235999.html
Zoomie that has a side COB, powerbank and looks like it uses 2*18650:
http://www.aliexpress.com/item/4000186069844.html
18650 with side switch and USB port:
http://www.aliexpress.com/item/33054536084.html
UV AAA zoomie? Does it use glass lens? With 395 nm it could be PMMA…a little expensive to throw out just to check.
https://www.aliexpress.com/item/32965761494.html
Rechargable 26650 zoomie with side switch:
http://www.aliexpress.com/item/32688681175.html
18650 with DC in and USB out:
http://www.aliexpress.com/item/32974082960.html
Tube style, quite compact 18650 UV zoomie:
http://www.aliexpress.com/item/32777599084.html
And the same zoomie under a different brand with white LED:
http://www.aliexpress.com/item/32568030549.html
Wow Agro, you seem to be on a zoomie model sharing frenzy. But I have to say many of them look crappy to me. :facepalm:
I must admit these “zoom in” and “zoom out” pictures look way more awesome than they will really look coming out from such awful torch, imho (with the exception of the beam tint).
Nice collection of zoomies Agro.
I have the Supfire A2. It’s not bad. Built-in charging and the button lights up bright green when the light is on. On the other hand, the UI isn’t great… long press for on/off and short press to change modes. And the light is fairly long…. too long in my opinion for pocket EDC.
I don’t have the one with the white central section. From the pictures it looks like the white head might be made of plastic. If that’s the case durability and thermal performance will be awful.
Yes, thanks for sharing, Agro!
Some of them look good, though I'm not huge zoomie fan.
Well, I’m certainly glad you’re digging them up. The more options I have of finding a suitable host, the better! :+1:
I think I'm gonna hurl after seeing all these cheapo zoomies, but, I think I own bout half of them
Another family of twisty zoomies with different lens sizes (up to 66 mm lens / 75 mm head).
They all take 18650.
http://www.aliexpress.com/item/4000321611399.html
These are really nice lights but again without anodized threads? I like design…
Another one for you Mike C:
http://www.aliexpress.com/item/4000222515753.html
And a fairly compact 18650 light:
http://www.aliexpress.com/item/32861169430.html
I finally ordered the P10 from here at Ali. Probably will come after the holidays, depends when it will ship, for real that is... NYS sales tax is tough to swallow now, but total is about the same at BG - could not get any discounts on BG because of reduced price. Now it says one order, guess that's me...
I’ve been using one of these for about a year. I like the form factor. I don’t like the bluish tint, the male USB charging under the tail cap, and especially the strobe in the main mode sequence.
I got it at half price via Vipon coupon and it’s good for the price and I carry it clipped to my belt daily. It seems pretty tough - it’s been popped off my belt and hit the ground many times and still works fine. It’s heavy enough that I’ve always heard it when it hits the ground, floor or whatever.
I’d love to have an AA size light in this format, but with better tint and UI.
Actually, I’d love to have this light updated with better UI and tint.
Dual e-switch, powerbank, side light… It can do a lot but it’s not among the most compact 18650 out there.
Thank you sir!
Once I get around to ordering, receiving and tearing some of these apart I can post a few pics of the internals. Most will be junk but with some luck and maybe some custom pills/spacers from kiriba-ru, some of these options should be good enough.
I’m sure I’ve seen these Led Lenser clones before but I fail to find them now. Also, they seem to be missing from this thread.
https://www.aliexpress.com/item/1842513598.html
26650 zoomie with charging:
https://www.fasttech.com/products/1601/10015804/9698024-authentic-ultrafire-uf-p52-led-flashlight-w-focus
3*18650 quad LED zoomie (with charging )
https://www.fasttech.com/products/1601/10009384/9708063-authentic-supfire-gf01-outdoor-fishing-led
Another 3*18650 quad LED zoomie (with charging )
https://www.fasttech.com/products/1601/10019425/9658887-tanlu-t450-led-flashlight-w-focus-zoom
18650 zoomie with charging:
http://www.supfireenglish.com/products/124-cn.html
https://www.aliexpress.com/item/33018495303.html
Cute Led Lenser inspired 18650 with charging:
https://www.aliexpress.com/item/32919028855.html
I’m not sure if I should trust it but the seller tells it’s 3*AAA with charging:
https://www.aliexpress.com/item/4000167211090.html
Slim tail-rechargable 18650:
https://www.aliexpress.com/item/32964273829.html
Another batch…
18650 with powerbank:
https://www.aliexpress.com/item/4000037444091.html
2*AAA penlights with a single LED that has dual CCT:
https://www.aliexpress.com/item/33060939120.html
UV zoomies with 365 nm + 395 nm:
https://www.aliexpress.com/item/33003995228.html
A smaller variant of the previously mentioned diving zoomie:
https://www.aliexpress.com/item/32961008285.html
Compact 110x31 mm 18650 zoomie. The bezel is sagging. But it’s small.
https://www.aliexpress.com/item/32882491361.html
A good looking diving zoomie:
And yet another diving zoomie, Archon W16U:
