I need some advice and help determining which DC power supply to buy for flashlight modding.
Probably could get by without one but just want to learn as much as possible.
There are switch mode and linear, 30V 3A, 30V 30A.
I’m not an electronics tech but want to have more fun.
Thanks for not laughing
I’m not an electronics geek myself, but have bought a few power supplies over the years for my flashlight hobby. My most used PS is a heavy lineair one but I understand that using a switched mode PS for what we do is perfectly fine. The one you linked is very cheap, so expect some imperfection, like bumpiness when finetuning the current, and spikes when switching the PS on, I expect you can blow sensitive leds with that (but not likely the power leds we are using). I think 5A max is a bit low, maybe 10A is more versatile.
A protected cell will cut off power once it reaches 2.5v. That is about the lowest safe voltage you can go. Below 2.5v the cells go through chemical changes which ruins them. They become fire hazards when charging. Keep tabs on how hot it gets.
I would contact the store you bought it from. It doesn’t sound like it’s protected, plus it’s ruined.
If the drain is very low, like what happens with a lighted tail flashlight, or one with high parasitic drain (FT02!!!), the protection circuit may not be triggered and the drain continues beyond the safe voltage.
Or am I mistaken with what some flashlight drivers do and will protected cells indeed detect the correct voltage and shut off even with very low drain?
I think I managed to get very unlucky. It is an EVVA 10A protected cell but it was stuck in the mail for a week and it wouldn’t charge for a few days after it got here. My charger read resistance to be 999mΩ, so I think I’ll see what I can do when It comes to sending it back.
The low voltage protection circuitry in a battery will cut power whenever the voltage gets to it’s lower limit, like around 2.5v.
The LVP in a driver like NarsilM and Anduril will only be active when the driver is active. For instance the light is left on at a low level. When you turn off the light, the MCU goes to sleep to reduce parasitic drain and the LVP is not working. Usually the parasitic drain, even with a lighted side switch, is so low it will take years to run down the battery, depending on the light model, of course.
so I think I reflow the solder on the board. twist it out. reflow the solder on the LED. remove. then solder the bead to that board. switch out the glass. then screw it all back together and solder the board back?
First you need to make sure your S2+ driver will not burn up that led. Ad says no more than 0.5A from driver. If you have the 8x7135 driver, you’ll need to remove all but 2 of the 7135 chips. 0.7A is probably okay.
It’s better to buy the led on the 16mm mcpcb so you dont have to reflow anything.
You won’t need the glass lens if you have the UV led.
I just want a switch I can run high amps through without issue, I have ordered the switch PCBs do I need a different or ‘upgraded’ switch or would say the standard switch from the convoy L6 suffice.
The standard L6 switch seems to hold up really well to like 18 amps or more. The weak part of the mechanical switch is the contacts. Whenever they close you get a power surge and maybe a flash. Not much, but it can build up carbon residue or something which adds resistance.
I’ve got spare L6 switches, but my original never had any problems. I swapped a new one in and measured no difference in lumen output.
If you want something really robust, Lexel was offering a FET based switch, but it doesnt fit inside the light, it mounts outside it.
For a more conventional design I’d stick to the stock switch.
I dont know of any upgrade version to the L6 switch, but you might ask on a L6 thread.
Potted lights? Is there a list somewhere of what lights are potted? Does it really make much difference or is it still pretty much the luck of the QC draw?
I ask this as I have been playing a lot with my new th20 lately and of course have dropped it a couple of times on concrete. Other than the physical dings there are no ill effects and frankly with my experience with Thrunite I don’t expect any. Perhaps I have just been lucky and perhaps Thrunite has decent quality control but isn’t the engineering of how the pill is put together and mounted a significant factor for at least what should be likely reliability? Are Thrunite lights potted? Seems quite a few members mod the th20 specifically to get a different emitter so this should be a known thing. All I know is they have excellent thermal management and hold up to drops. This could be because of potting? There is so much I don’t know.
