I haven’t purchased the first one either. Probably not going to. Not that it isn’t a great offering at a great price, it is, just that there are other lights I would prefer and CAN’T BUY EM ALL!
Sorry, searched and could not find the ‘dimensions’ of the lantern. I want it so I can shop for a cheap neoprene camera lens case to protect it. Anybody know the dimensions?
We need a LT1 wiki. Too much non-factual info (questions, tears, etc) in this thread and would be great to have a reference.
Just found a tint ramp bug on my LT1. You may reproduce it as follows:
1. Reset to factory default (not really necessary, just to ensure a common beginning) 2. Enter the lowest brightness with the default stepped ramping. 3. Ramp the tint to the warmest or the coldest side. 4. Now stepped ramp to higher brightness levels, and you’ll see it. If you chose to ramp the tint to the warmest side, now the tint gets cooler when the brightness is ramping up. If you chose to ramp the tint to the coldest side, now the tint gets warmer when the brightness is ramping up.
It is not a firmware problem, it is the design. One can choose to have warm tint at low light, and cool tint at bright light, or the converse. That has been discussed in this thread previously.
regarding the programming pads,
Not sure what version of the programming key you have, but it appears some small mods need to be made to work with the LT1. I don’t know anything more than this regarding the key. I do know that connecting directly to the chip works fine.
Good. Thanks for the info. It’s almost impossible to follow ~9900 posts to learn this fact… :person_facepalming:
Of course I’m using the Lexel one, not the Emisar one. I own both, and I have confirmed that the pins on the Lexel one do match those holes on both ROT66G2 and LT1. However that just didn’t work. I don’t like to pull out the driver each time for a firmware upgrade.
I also soldered wires directly from those programming “holes” to the USBASP programmer. However it didn’t work either. So most likely those holes themselves are not working at all in the design circuit, or both my ROT66G2 and LT1 are defective units.
I did successfully reflash my Emisar D4S, D4V2, Fireflies E01, PL47G2. I suppose I know how to do this correctly with programming “holes” or “pads”.
Regarding the programming, maybe Lexel can help here then. I don’t know the order of the pads, but one could fairly easily figure out what pads go to which pins on the Attiny85, but it would require removing the board once.
Lexel did test a prototype board, and I’m almost certain ToyKeeper has reprogrammed the LT1 via the pads several times, as she provided me a few builds to test. Maybe she also knows if there is some specific wire swap that needs to be made.
Sorry I can’t help more, if/when you learn something please post it.
It uses Lexel’s standard layout, and the mappings are also printed on the circuit board if you have a way to look closely enough. Then match those up to the usbasp’s pinouts and it should work.
If you’ve successfully flashed a FF PL47 or FF E01, the same adapter should work for the LT1.
Here are the pinouts on both ends:
It’s not strictly necessary, especially in a large sphere. In a small sphere though, having a big black object inside might reduce the integrating capabilities enough to cause issues, and making those parts reflective could potentially reduce that effect.
I don’t know if it would really be helpful or not; it’s just an obvious thing to try if measuring in a relatively small sphere.
That’s also my understanding. However the same configuration works well on PL47G2 and E01, but never works, on neither ROT66G2 nor LT1. That’s why I reported this problem here.
I’ve tried hundreds of times, spending hours on this. I even soldered wires directly from those programming holes on the driver board to my USBASP programmer, trying to flash without the adapter. Still failed.
EDIT: Actually I reported this problem to Fireflies weeks ago when encountering this problem on my ROT66G2.
Later they told me they contacted the foreign author of the driver circuit but no response from him (thus no answer for me). Now since I meet exactly the same problem on LT1, I report it again here.
