Just to update the resistor mod for changing low and med resistors. Changing them around on the Lumintop aaa tool, (not Drop aaa tool) does not work. You will end up with low,low, and high. This is for the Lumintop version that has med, low, high in that order. I think the reason is that in med the current runs just thru the med resistor (1 ohm) so changing it to a higher resistance (10 ohm or higher) gives you a low in the first mod. But when you click on off for the next mode which is original low mode, now the current switches to run thru original low resistor first which is in series with the med resistor to the led. Now the current is running thru both resistors and is low also. I havent probed around with the circuit actually running but in my lumen tube both modes (med and low) produce about the same lumens with the resistors switched around. I think this could probably be fixed by cutting the traces to the fet’s gate and rearranging them. I havent tested that yet but when the mode contoller or mcu (not sure which it is) says turn on med first instead it turns on low fet and when it cycles to next mode it says turn on low fet and it would turn on med fet. No resistors would have to be changed. Its just a matter of fouling the controller in which fet to turn on. If anyone happens to try this please post up your findings. This will probably not be easy to do since its so tiny, so try at your own risk.
Please note this is for the original Lumintop AAA tool not the Drop tool being discussed in this thread. They are the same except mode order. Changing the low resistor to a higher value still gives you a lower low in either version of the tool.
My Nichia order finally arrived yesterday and guess what… Cree XPG3. Too bad. Replied to the Drop CS email and they claim to have Nichia units available to swap mine with. I”ll ship it back (by pre-paid label) Monday and in another 4-6wks we will see if they were telling the truth!
I dropped mine off with UPS on Saturday, Just a couple hours later, I got an email from Brett saying that he sees the RMA package is on the way and he initiated the replacement process at Drop. I guess they have some kind of UPS receipt trigger service to the RMA originator. Seriously impressive customer service!
One of the advantages of being outside the USA. Drop considers the shipping too costly so customer gets a freebie. In USA, it’s a different story… we get a swap.
I also ordered the Nichia version but unfortunately I received the Cree version. I contacted Drop customer service and they said they had limited inventory of the Nichia and asked me to provide a shipping address so they could start an exchange. I sent them my address and then they responded that they no longer had any inventory of the Nichia. Very frustrating…
Mine finally arrived. Literally sat in a warehouse 15 minutes from my house for a week and now apparently it’s too late for an exchange. Really pretty frustrating, but I guess for the price I can live with the screw up.
What I don’t get is that it’s clearly marked Cree. So when these are opened up are the items as marked?, or has anyone opened one marked Cree and found it’s actually Nichia or vice versa? Also thinking about gifting this light so don’t want to open it if I did receive the wrong emitter.
If it’s clearly marked Cree in the packing and the light is actually Cree, how did the “mix-up actually happen?
ALERT: I realized I had a spare email account I could use for this, so I signed up. Got the $20 off coupon. There’s an asterisk… I check it. Coupon requires a purchase of a product over $50 now. Raised up from the prior $30. I guess too many people were taking advantage of it. Oh well…
Btw, if you select an item less than $50, you can increase quantity until you’re over $50 to qualify for applying the $20 coupon.
Yeah, I was able to order 2 lights earlier, one copper and one titanium. I wasn’t going to get any more, actually — had my eye on something else from Massdrop brand. Btw, I should clarify, that the “more than one item” is only quantity. I can’t see any way to “add to cart.” Each item is treated as an order, with the option to increase quantity.
I also got a Cree instead of a Nichia version yesterday. This is my first copper torch, so I’m going to keep it. I will probably just apply a Lee filter to the lens to warm the tint. I already swapped the inadequate stock clip with one from a Streamlight Stylus Pro, so now the torch rides deep in my pocket.
