2019 Flashlight Host and Uncommon Budget Flashlights
557 posts / 0 new
djozz
djozz's picture
Last seen: 38 min 57 sec ago
In this set-up you need button top cells both for driver contact and for battery-battery contact in the middle.
JasonWW
JasonWW's picture
Last seen: 28 min 12 sec ago
I asked TA if he worked on this light or if Haikelite is just adapting his older MT09R driver without his knowledge. If he worked on it he might have some insight into it’s performance.
Update, he didn’t work on it. Haikelite must have adapted the driver themselves.
Click this to go to signature links.
freeme
freeme's picture
Last seen: 4 min 28 sec ago
surprised
©freemex1thedeals.com
luminarium iaculator
luminarium iaculator's picture
Last seen: 20 hours 36 min ago
That one is like Supwildfire(Mitko super thrower) on steroids and neck switch Smile
Skylight
Skylight's picture
Last seen: 2 hours 39 min ago
Agro
Agro's picture
Last seen: 2 hours 35 min ago
There is some discussion as well as links to cheaper (but potentially lacking powerbank) variants here
freeme
freeme's picture
26650
127mm x 36mm
Skylight
Skylight's picture
Thank you! It is really cheaper on Aliexpress.
Agro
Agro's picture
I have a feeling it’s plastic junk but I like the use of 2*18650 and overall format.
http://www.aliexpress.com/item/32733422105.html
freeme
freeme's picture
One can assume light has unbranded emitter installed when you see "CREE T6" for specs.
Agro wrote:
I have a feeling it's plastic junk but I like the use of 2*18650 and overall format. !https://ae01.alicdn.com/kf/HTB10xhXXx2rK1RkSnhJq6ykdpXaZ/LED-powerful-hu...! http://www.aliexpress.com/item/32733422105.html[/quote]
freeme
freeme's picture
This could be the weirdest flashlight for 2019 innocent
gchart
gchart's picture
Last seen: 1 min 28 sec ago
will34
will34's picture
Last seen: 2 days 17 hours ago
That switch looks like convoy BD series with recharge contact points. Weird looking light
KnHawke
KnHawke's picture
Last seen: 2 days 11 hours ago
Agro wrote:
I have a feeling it’s plastic junk but I like the use of 2*18650 and overall format. http://www.aliexpress.com/item/32733422105.html
As do I, but would love a 21700 type, slap on an L2 Head… hmmmm
Definitely not liking the Plastic Fantastic. Looks REALLY cheap.
Agro
Agro's picture
Flashlight that uses Makita battery packs.
https://www.aliexpress.com/item/4000301855017.html
JasonWW
JasonWW's picture
Tool battery pack powered flashlights are very common.
Agro
Agro's picture
Agro
Agro's picture
Jack Kellar
Jack Kellar's picture
Last seen: 5 hours 42 min ago
Agro wrote:
http://www.aliexpress.com/item/32952817482.html
I can see a train hopper using this Big Smile
Photonica
Photonica's picture
Last seen: 3 min 11 sec ago
How did the BriteBucket avoid this list? It’s not a host, heck, it might not even be a flashlight! But it has it’s own song.
Brought to you by Nebo, “We’ll Put a Light in Anything!”
More Photons!
adirondackdestroyer
Last seen: 1 hour 16 min ago
I have a hat with a built in light that uses coin cells, so once they died I pretty much never used it again.
I can see this being very useful for the average person, if they’re walking the dog in the winter or other things where you don’t need a ton of light.
Is there any other place to buy this from? When I selected USA on the site it changed the currency to something I didn’t understand.
Photonica
Photonica's picture
Amazon has them at $8.
Search for “LED USB Beanie”.
More Photons!
pennzy
pennzy's picture
Last seen: 8 min 8 sec ago
Search them on Vipon. I saw them there before.
pennzy
pennzy's picture
Agro
Agro's picture
JasonWW
JasonWW's picture
Definitely not budget.
Agro
Agro's picture
This light is probably plastic junk but I like:
  • screw-on magnet that doesn’t add size for those who don’t use it
  • right angle headlamp with mule emitter on battery tube? Nice implementation of flood-to-throw. Smile
http://www.aliexpress.com/item/33036830454.html
vresto
vresto's picture
Last seen: 1 hour 29 min ago
freeme wrote:
26650
127mm x 36mm
whats this please??
EDC- Jetbeam E40R,Emisar D4V2 XPLHI
Headlamp-Thrunite th30
TexasToasted
TexasToasted's picture
Last seen: 18 min 4 sec ago
vresto wrote:
freeme wrote:
26650
127mm x 36mm
whats this please??
I have this light. Got it here.
It’s not too bad. Main LED is cool white, side LEDS are cool white and red.
Single click turns on main LED. Click to cycle through high, mid, low, strobe, repeating. Does have memory. Long press about a second to turn off.
Double click to turn on side LED. single click to cycle through solid white, solid red, slow blink red, fast blink red/white, repeating. Does have memory, but if you switch to mail LED, the side LED memory gets reset back to solid white. Double click to go back to mail LED, or long press to turn off.
Draws 27uA while off, 2.2A high. 1A mid, 0.3A low.
Side LED .1A solid white, .05A solid red.
Driver is easy access. Just unscrew the battery tube and remove the threaded retaining ring. There are a lot of wires on the driver. 4 to the switch (lighted), 3 to each side LED assembly, and 2 for the main LED.
LED is also easy access. Just unscrew the bezel- no glue anywhere. Led is on a standard 20mm board. I’ll replace the main LED with something more neutral, but I’m leaving the rest of the light as is.
Agro
Agro's picture
Please excuse me stretching the definition of a flashlight but I think this way of using flex PCBs and magnets is interesting yet not worth its own thread.
http://www.aliexpress.com/item/4000145698500.html
