I’m sorry l.i. but although I produced the AK-47 hack back in the days, which was purely an extension of comfychair’s work, I’m not very knowledgable in drivers, not like Texas_Ace or Lexel or DEL or wight.
The idea of putting an extra resistor in this hacked driver is not a really practical one because it would have to be a big one that can handle 5A current.
Maybe if you can guarantee buying a large amount of them, you could ask Simon from Convoy Flashlight to produce a batch of his 5A drivers with high-med-low without memory?
Yes I could. But what should I do with hundreds of AK47C1 drivers(also ordered from Simon) ? I would try to place big resistor on driver cause I pot drivers anyway. Can you suggest me proper resistor for this potential current restriction FET driver mod?
Is there any way to put some kind of resistor on a top of a driver and where would you put it? I pot drivers so it would be nice if I could merge resistor with a driver for permanent bond :+1:
You would put the resistor anywhere in the main current path. The challenge is the heat dissipation. It will be producing between 2 and 5W depending on what current you choose (5 to 7A), and that is a lot for a small resistor so it will get very hot.
EasyB,
Can it fit to 17mm diameter? Can I cut it to fit if needed? I have aluminum and copper plates as potential heat sink for resistor and when I merge everything with potting compound it will look like it is made from one piece and whole driver should act as a heatsink.
But if it generates serious heat at 5A (more than 60 celzius) that could be problem…
The extra heat is not large compared to the total heat from the LED. The risk is that if the resistor you choose is too small or not heat sinked enough it will burn up. You will have to look for resistors that will fit in your lights.
Can you link me some kind of big but no to big resistor that could be bent into 17mm diameter please. I really don’t know what to order? Pretty please…
Okay, so the ‘boost HX’ is basically the 2mm² white flat with a 4040 footprint.
So the 1mm² white flat with 4040 footprint will probably beat it in throw (like with the 3030 sizes)?
@Jerommel
Yes. Boost line seems to take a given chip and move it up one package size/class. This probably didn’t mean much for the 1mm² chip but should for the 2mm² . Where 1mm² saw a ~10% “boost” in current handling, I would expect 15-20% for the 2mm² . This might close the gap entirely between these two. The choice between would then be based on your host/driver/runtime restrictions.
@Fat_Controller
Interestingly the If vs Vf curve maxes out at 8A (despite 6A rating)! That should mean we have a bit of overhead there I would imagine…
EDIT: Looking at the datasheet for the 1mm² (Boost HL) it appears they did the same thing. If vs Vf goes up to 4A and max rating is 3A. If overhead is proportional then the HX should be good for 12A. We’ll still just have to see if the HX ever shows up.
PS: Interesting to note as well, the HL product page notes it’s “not for new designs”. I wonder what why? Is there a successor already?
