Hi Martin, link goes to $18.99 so two dollars more than what you posted. I have been on the fence for this set for a year now, and it has been this price a few times before (was it ever 45 dollar?) but I need that two extra dollar off to make me buy it :innocent:
Hello my dear friends!
i got a nice deal from banggood.com to make the new added Shockli cells even more affordable!
12% OFF on all SHOCKLI cells with my code: MSLB
2PCS Shockli IMR 26650 3.7V 5250mah 20A Discharge Rechargeable Li-ion Battery-Flat top
Shockli 21700 Battery 4550mAh Flat top High Drain 22A 3.7V Li-ion Rechargeable Battery – 2PCS
Shockli 14500 1000mAh Button Top Unprotected 5A 3.7V Li-ion Rechargeable Battery – 2PCS+battery case
Shockli 18650 3100mAh Flat Top High Drain 30A 3.7V Li-ion Rechargeable Battery – 2PCS+Battery Case
ShockLi 21700 4000mAh Flat Top High Drain 20A 3.7V Li-ion Rechargeable Battery – 2PCS+Battery Case
@djozz
i try....
Do you know which cells are inside this shocklis?
I am searching for VTC6 and 40T.
The $2 is because of the free shipping, so…
AMUTORCH XT35 SST40 DD 2000LM 5000K/6500K LED Tactical Flashlight 21700 Powerful Flashlight
my code: M5534 your price: US$ 35.99
The Shockli links don’t work.
don´t they take you to the brand page?
sorry, but this are not the cells you are looking for
It was not a trick.
Received today, everything is correct.
Sorry for the mistrust but lately I’ve seen many gifts that turned out to be tricks…
Thanks!
Edit: Potential short circuit in the tailcap between the spring and the track, reported by DBSAR on the FW3A , continues on the FW21.
Today I received an FW21 and when doing the visual inspection prior to commissioning it can detect it.
I will correct it by rotating the spring.
So Amutorch is another company to offer dedomed SST-40 after Maxtoch and Kaidomain (ADDED: and Nightwatch).
Can’t wait for CRI95 SST-40 to come out. Dedomed, it will be an awesome emitter.
How does the tint look on the Maxtoch and Kaidomain dedomed sst40? The one in the Nightwatch NI40 is extremely green.
I have sst-40 De-Domed 5000K in Astrolux EC01. it’s surprisingly throwy considering OP ref and size. Green on lower currents but at full throttle becames acceptably neutral.
Hi m4dm4x, code M4BG doesn’t work anymore.
Do you have a special price for the Rofis R3?
Astrolux started a Xmas Promotion!
30% OFF with the code : AXMAS
works on whole Astrolux (except promotions)
Thanks for all your code work !!!
I added some deals for you!
please find them on my blog or PM me
(please follow my links to the shop for more information)
Fireflies E07
SST20/XPL 6900Lumens 4000K/5000K
CU TI / Brass Limited Edition
RED Aux or BLUE Aux
Nitecore New P30
1000LM 676 Yard Long Throw
+1Pcs Nitecore 21700 USB-C Rechargeable Battery
NITECORE UAC20
3.3ft USB Cable Type C 3A Fast Charging Cable
Max - (M4X?)
I had a couple of full-priced Astrolux items in my cart & tried to use “AXMAS”. I got the error message “This coupon can only be used on products from a specific brand and on orders over a certain amount.”
Could you confirm the code and conditions?
Thanks for all you do!
