[♛ FreemeGB-NOV] Haikelite HT70 4*SST70 6500k 17000 lumens 18650 Flashlight - ALIVE!
True but reputation is important too. Olight sells the most flashlights and all of their lights measure higher than Olight’s specs in my calibrated lumen tube. My lumen tube usually measures lower than others on this forum. So even a company that under rates their products can sell really well due to their reputation and reliability.
On Banggoods website there is a section for questions. One question was can it take FLAT TOPS? The answer was YES.
Q:Can it take flat top batteries?
A:
yes
Answered by wangyanyi on November 14,2019
Can you confirm or refute this?
Thanks
This is why I asked the question in post #82 about GA BT OR FT??
I would like casi29061965 to answer the question OR someone who actually has the light.
Thanks
Two batteries are always in series and there is no battery holder, so if I’m correct that would mean it depends on whether the positive terminal of a battery will make contact with its negative end.
True. But there is also a possibility that the length of two flat top GA cells in series is on the short side or too short to make proper contact.
lol! There is a reason why I asked casi29061965 OR someone who actually has the light…………other than that it is pure speculation. :wink:
You have to know your cells.
Sanyo GA are considered raised flat tops, not flat tops. If you look at them you can see they stick up and will make series contact.
Regular flat tops will not work.
Raised flat tops or button top will work.
Appreciate your opinions, but like I said, it is All speculation until someone tries these FT cells in this light.
Knowing cells helps but is not definitive until they are tried in the light! Every light can be different.
Still waiting for someone who actually Has the light! lol!
I hate to say this, but your quite wrong. This particular flashlight is irrelevant. It only depends on the cells. If you have 2 of a particular cell you can see for yourself if they will make contact in series or not. Or better yet, take a single cell and a straight edge and see it the top extends above the wrapper.
Look at this picture, you see there is a black ring around the brass ? disc in the middle. This means the positive battery end needs to stick up a little bit. All button tops will work. All solder blobbed flat top will work. (The black ring is there for reverse polarity protection)
Button top only. I thought i have mentioned before?
Yes you did mention it.
I will disregard the post on Banggood[Where the question was posed and replied FT will work] an one members opinion on here about FT!
Thanks
Are you still expecting December 31st as the “Target” date for NW to come to fruition?
Thanks
Update…
Mine is walking through China… 2 shipments… 2 tracking numbers… 1 returned to origin… 1 returning to origin…
It still did not leave China!
First tracking number: Hangzhou -> Beijing -> Shanghai -> Hangzhou.
  • 2019-12-09 06:30, Hangzhou, leaving the Hangzhou Center, the next stop , Hangzhou International Mail
  • 2019-12-08 18:43, Hangzhou, arrival in Hangzhou Center
  • 2019-12-08 14:45, Shanghai, leaving the Shanghai Central Bureau Mail Processing Center, the next stop , Hangzhou Center (via transfer)
  • 2019-12-08 02:57, Shanghai, arriving at the Shanghai Station Mail Processing Sub-Center (via transfer)
  • 2019-12-07 07:50, Beijing, leaving Huangcun Station, the next stop , Shanghai Station Mail Processing Sub-Center (via transfer)
  • 2019-12-03 13:29, Beijing, Beijing Post International return, note: security return
  • 2019-12-01 15:37, Beijing, Beijing Exchange Station Return
  • 2019-11-30 15:20, CHINA, EXIT OF ORIGIN
  • 2019-11-30 06:35, Beijing, delivered to air transport
  • 2019-11-29 10:07, CHINA, PROCESSED IN OFFICE OF ORIGIN
  • 2019-11-29 10:07, Beijing, Beijing Post International has been exported directly sealed
  • 2019-11-29 00:50, Beijing, arriving at the International Mail Transfer Department (via transfer)
  • 2019-11-27 22:12, Hangzhou, arrival in Hangzhou Center
  • 2019-11-27 20:41, Hangzhou, leaving Hangzhou International Mail, next stop , Hangzhou Center
  • 2019-11-26 23:25, Hangzhou, leaving the Hangzhou International Small Package Collection Center, the next stop , Hangzhou International
  • 2019-11-26 20:41, CHINA, HOME COUNTRY ADMISSION
  • 2019-11-26 20:41, Hangzhou City, “Hangzhou International Small Package Collection Center” has received, pitcher: Sun Luzhu
  • 2019-11-24 16:43, Logistics order created
Second tracking number: Dongguan -> Guangzhou -> Beijing -> Guangzhou…
  • 2019-12-22 01:42, Beijing, leaving Huangcun Station, next stop Guangzhou International (via transfer)
  • 2019-12-20 20:35, Beijing, Import Customs Release
  • 2019-12-19 20:23, Beijing, arriving at Beijing Terminal (via transfer)
  • 2019-12-18 13:41, Guangzhou, leaving Guangzhou Terminal, the next stop , Beijing Terminal (via transfer)
  • 2019-12-17 21:59, Guangzhou, arriving at Guangzhou International (via transfer)
  • 2019-12-17 19:24, Dongguan City, leaving Dongguan International, the next stop , Guangzhou International
  • 2019-12-16 17:38, Dongguan City, leaving the “package express bulk business department back-office support class”, the next stop “Dongguan International”
  • 2019-12-16 17:32, CHINA, HOME COUNTRY ADMISSION
  • 2019-12-16 17:32, Dongguan City, “Parcel Express bulk business department back-office support class” has received, agent: dg3
  • 2019-12-13 19:51, Logistics order created
The package contains only a HT70.
its one of busiest holidays around corner… expect delays for packages to leave china.
Christmas is around the corner. Chinese New Year is January 25th to February 8th.
BUT his package started moving on November 26th, almost 1 month ago!There is not any progress,very little at most. :person_facepalming:
I am thankful for his post it helped me solidify my decision regarding this light. He may have to wait until late February or March! Totally unacceptable from an American standard and point of view.
I know but still keep in mind that buying stuff from china just is what it is… tons of packages end of year, and also next year when chinese new year starts…
If they were so busy they would not be sending packages between one office to another, they would simply get rid of them sending them to destination…
What is happening is what in my country we call bureaucratic gymnastics.
Thanks for the video! :smiley:
You think they are sending his packages between one office and another? I’ve never seen or heard of this happening. My assumption was the package was returned to the sender for some reason. I see this quite a lot and it’s happened to me a few times.
The tracking info is very confusing, but it looks like the first package was returned due a security concern. Maybe battery related? Hard to say.
So it looks like the package was sent again, but the 3rd party shipper sent it through a different mail hub or whatever hoping it would get through security and customs this time.
I guess we have to wait and see if it gets through.
Hi Freeme
I'm Interested
Okay.
