- When connecting TC66C or any other USB-C power meter, like Satechi or Plugable, directly to Baseus C port, power meters don’t power on until I connect some load like charging a phone. If disconnecting the load, the meter powers off again.
However, If I connect a USB-A meter like YZXstudio to the A port of the Baseus, it powers on immediately even with no load.
Doesn’t this make sense, since PD prevents from sending power until some specific bus data is received? Or power meters already send some signal so it should power or? I don’t have any other PD wall or car charger to test it so I don’t know how it should behave.
Now if I connect the TC66C directly to the C port of the Baseus your meter doesn’t turn on: Baseus <-> TC66C—- this is not charger and TC66C problem, this is PD charger feature, if you want it turn , please turn on our PD switch, it will turn on
Tried again connecting TC66C to C port of Baseus, but still doesn’t power on without load. Tested with buttons C and D of the meter in all 4 available positions but still doesn’t turn on.
Hi, I sent you the video to your PM. You can see how I connect the meter in all 4 available positions of the switches, and it never turns on witout load. With load, sometimes the meter screen powers on and others not, but always charges the load when connected. By the way, the car charger specific model is the Baseus BS-C20C, it’s written on the case.
Ok finally found how to turn on TC66C meter when it’s standalone connected to PD port of Baseus BS-C20C. You need C physical switch on (POWER) + D physical switch on (POWER DELIVERY) + AG virtual setting ON on Settings menu (CC line mode choice / PD SOFTSWITCH). The 3 are required enabled to turn on. I had the AG setting off thus didn’t turn on without load even with the other two on.
Hello again, I’ve found another issue with TC66C and Baseus BS-C20C:
Connect TC66C to Baseus in PROTOCOL DETECTION mode, then use a power supply to power the Baseus.
1- Set power supply to 13 vols and do protocol detection
2- When finished, increase power supply voltage from 13 to 24, with power supply still ON, do not disconnect voltage source.
3- Now when trying to perform protocol detection again the TC66C turns off and on again.
4- Same thing happens when lowering voltage from 24 to 13
5- Happens on both USB-A and USB-C port
6- Other Baseus car chargers that don’t have 20V output the issue does not happen.
I’ve not yet encountered the “Fail” message yet when updating the KM001, I’ve been able to update it a number of times already.
Does the KM001 that “Failed” work properly, except it does not want to update firmware?
Can you try changing a different micro-USB cable when you’re trying to update the firmware? (just guessing — it could be the USB connector does not properly connect with that specific KM001 meter maybe due to connector contact issue or something — or connect/reconnect a few times and try again)
Also, maybe try to do a Factory Reset on the meter (it’s in the last page of the Settings screen of the KM001 meter)
How can I know if my YZXstudio ZY1270 has bluetooth or not?
If not, how can I connect it using microUSB to pc to read serial data? Any help for Windows, macOS or Linux would really help.
To see if it has Bluetooth or not look at the back of the main PCB of the unit, it should have pogo pins that connect to a smaller blue board that has a zigzag copper trace on it (which serves as the antenna), that’s the Bluetooth chip.
Ok what I did is to remove the screws at the back of the YZXstudio ZY1270 with a PH00 screwdriver. In fact there were only 3 on them, one missing, and were barely loose. One of the copper cylindrical separators was a little bit unscrewed, so tightened it up, in case the bluetooth module pins (they are retractable) didn’t touch the pads. Set the serial update to 1 seconds and no bluetooth device is found by the smartphone right away, but if I use “hcitool scan” on linux it does find the “SPP-CA” device instantly. For the device to be found on the Galaxy S10 it takes about 40 seconds to find it and you have to press “Scan” twice on bt settings, so if you are eager you may think it’s not working.
Now what’s left is how to read the data from either the smartphone or Linux or Windows. Do I have to pair the bluetooth device or does the app just have a device selector? How can I do it?
EDITED: found how to do it. You have to pair the smartphone to “SPP-CA” with PIN 1234. Then I used the app Serial Bluetooth Terminal from Kai Morich. Then click on menu - Devices and choose the paired device. Then on Terminal tab click on connect icon and that’s it, will output the time, voltage and amperage. It has option to save, share and Log. Probably the way to save everything is to enable “Log”, otherwise after a while toasts the error:
Hint: Receive buffer truncated. Try ‘Settings -> Receive -> Buffer size’
You can click home button on phone to open other apps and it will continue working in the background.
