Any codes for the 28th or 29th?
Looking for updated codes also.
Day 4 (29th December):
Code 1: QBEQ-FMVJ83-3SM5A6
Code 2: QB2S-3UC3GA-2JVZA4
Code 3: QBCX-FC9L57-YBB7AT
Code 4: QB5U-7AQLUL-XBGFAL
Code 5: QBME-XLT9P4-GH7TA6
Code 6: QBRE-C7CQKR-Q8NYAC
Code 7: QBSU-Z9Q9NL-A94YA2
Code 8: QBBY-P6TLPK-JJ7DAN
28th and 29th are updated now.
Updated just now, thank you.
Bah. Tried all 16, all invalid. I’m out…
Used Code 8.
Thanks Barry!
Lightbringer try again - just used code 4 and it worked. Thanks Barry!
Huh… Tried a few which didn’t work, but code 2 eventually did. Kewl!
So that’s code 2 down, tnx Barry!
Used code 3. Got one for a friend who saw mine and wants one. Thanks!!!
Day 5: (30th December):
Code 1: QB3J-EWGH88-U5UNAL
Code 2: QB8F-HGWW2B-X4KXAR
Code 3: QBTJ-2Y8JVS-EN74AK
Code 4: QBZR-J9L7FJ-4XNMAD
Code 5: QBM5-99L77B-6F3YA7
Code 6: QBQS-X3HLDS-5NHLAH
Code 7: QB3U-Q3BCNY-2JZZAX
Code 8: QB7X-2ANJKP-7ZVWAV
Welcome.
Used Code 1 for Dec 30, thank you!
Used code 8 for Dec 30. Thanks!
Mine came in today. I guess for $18 i can’t complain to much. Build quality seems a little low to what I’ve come to expect from Sofirn. Threads on one end were a little messed up with a loose sliver of metal hanging off of one thread. Cap seems pretty thin as well. The clip that the light snaps into is all plastic. There is a small plastic piece that serves as the angular adjustment for the lamp and meshes into the metal body. It doesn’t take much to move it and first time I grabbed the light to take it off my head, I pulled it out of the clip. The light is plenty bright enough and the UI is decent but the build quality is a little lacking. It won’t replace my Fenix nor was I expecting it to. It’ll serve the purpose for occasional use.
Yeh, they’re like that. Based on the (“original”?) Boruit. Always hated the headbands for precisely the reason you mentioned.
Thanks for the coupon Barry 0892. Friday 01/03/2020 is the arrival date for my headlamp.
Just a reminder for new owners - Member gchart designed an improved headlamp holder that fits on the existing band, and released the files to the Thingiverse. My public library will 3D print for a little more than the cost of materials!
That’s what I love about this place - show us a flashlight, and someone will surprise you with an improvement!
dec. 30th codes #4 today, Thank you
Hi LOTL, does your headlamp works? Please do not worry the clip, it can be stuck well usually. And if you think the clip much loose, and the headlamp will falling out, then the clip may defective, please feel free contact us for replacemment headband. Sorry
