Okay, so I’ve pulled apart my MF01 driver (the buck one, v2.1) that I got from you; everything’s working fine, just re-wiring it. Just testing with the DMM and I seem to be getting 140-150 ohms between LED+ and LED-. Unsure if that’s expected behaviour; seems to be happening on both sets of emitter wires. Open to thoughts! I’m reflowing it now on a heating platform in case I’ve done something stupid somehow.
OR
Is it possible to get this image redone without the components on it, so I can trace and isolate?
Measuring this is no defect its just that the Shottky diode gets conductive by your DMM
they respond very fast and can deliver high currents but also have a quite considerable leak current
diode test shows me one side about 0.1V the other side 2.8V
a proper test would be a current-limited source of like 1A and then measure the current in both ways
Awesome, thanks mate. Was just re-doing my wiring on it, and got a short (thankfully tested before putting power to it), and have been chasing it down and then noticed that.
Lexel what is the minimum input voltage that could be used for one of these larger boost drivers? Would it be possible to power an XPL with this using only 2 NIMH cells? If so what would be the maximum possible drive current for the LED?
Those drivers are specific for UVC LEDs its working fine with 8V and 500mA, the chips input switching limit is 1.2A so 8V 500mA is pretty much at its limit
its >3V input voltage so only lithium battery
