Sent. [quote=bling04] Interested. Can I request for a group buy price coupon? [/quote]
Interested in the group buy coupon.
Can I get a new coupon code?
My order was just canceled refunded by Banggood, apparently due to customs rejection.
I like Sand color, 5000k.
Thx!
Interested in a code. Thanks!
I never got to picking up an MF01S but I’m very curious. I do have an emisar D18 with XPL- Hi and would like to know how they compare in terms of the sustainable output. Can some mf01s owner share what sustainable lumen level the mf01s goes to after a)1 time turbo application 2) without turbo application ( starting from on that sustainable lumen level)?
Thanks!
Does MF01-S work with the 8x18650 tube? I don’t have tube, but does it put out 9v? I assume it puts the two sets of 4 in series… the MF01 non-S input voltage has a range up to 9v so that’d make sense. MF01-S doesn’t have any input range given?
This light is 6v (8.4v).
An 8 cell battery tube would need to maintain 6v.
The existing Astrolux extender works in parallel not series with MF01S just like with original MF01. You will need to buy additional one end cap and have two loose battery cages since new MF01S changed design with integrated battery holder.
Does an expanded tube help with heat dissipation?
Or, with 8 batteries, does the lamp adjust in high / turbo mode just as fast?
The vast majority of the heat is at the far end of the head, above the switch level. So the battery tube heat dissipation is very small. I doubt you will see much heat related difference with a longer battery tube. Any difference will be tiny and you might not notice.
Turbo stepdown should not change.
Depending on batteries, you might see brighter Turbo output which means it could heat up faster.
I think the main goal of using 8 cells is just longer runtime. All run times double, except where heat might cause it to ramp down.
I have two MF01S (4000K and 5000K) using the astrolux extender tube (about 20€) and they work nicely! The original MF01 worsk with it as well and the MF04 ditto.
No Problems whatsoever.
The main advantage is longer runtime. In real world I don’t see an output advantage (i.e. more light on turbo) but turbo can be maintained a little longer…
But be aware, this then is a heavy flashlight and no beauty since the tube is nearly as thick as the emitter end
Cool just extender tube, extra caddy, and tailcap in… hooked it all up and yeah works just great. Yeah its mostly about runtime… I’m pretty sure output is a bit higher as well. I can’t really see a difference, so its not huge deal, but just based off heat its driving leds harder. I had setup ceiling to be at point where light just was slightly warm in hand, was like level 100/150 or something. Switching to extender tube same level is now noticabely warmer, so more amps must be flowing due to smaller voltage drop with twice batteries in parallel.
My Mf01s came without the physical reverse polarity protection rings.
Did they change the design? Does anybody else have a Mf01s without it?
In this vietnamese youtube review of the Mf01s it seems to be the same:
youtube link
Mine came also without reverse polarity protection rings.
Was delivered early december. So it seems they changed it quite a while ago.
Thanks for checking.
I bought four Samsung 30Q button top because I thought it would come with the protection. Would have taken flat tops if I knew before.
Well, I’m happy they work both, so I can use my Sony button top or Samsung flat top.
Mine was an early MF01S and it has the protection rings.
Thats not good that the newer do not have it. That was the best polarity protection rings on the market, because they works also with all flat top batteries. E.g. from Samsung, which has the contact lower than the heatshrinktube around the flat top.
I will find out from them next week.
