Pretty expensive nightlight.
Reylight Pineapple, Zebralight and a build with the H17F driver.
Zebralight used to be the king of moonlight mode with their 0.01lm lowest low mode.
Now they’ve raised it to 0.07lm because they think nobody needs 0.01lumens (wrong). The difference between the two is big.
The current moonligh mode champion will be a 2000K Nichia E21A modded Wizard Pro with a firefly of 0,02 lumens. That combined with a much more difused optic means it will beat the crap out of a Mk IV Zebralight when it comes to super low modes.
When did they make this change? I have an SC64 LE and I’m now wondering what the lowest low on mine really is… :weary:
Is your goal longest runtime or lowest output?
The RRT-01 goes extremely low, but my understanding is the driver overhead uses far more power than the LED at those levels. As a result, it’s great for people who demand minimal lighting, but not for ultra-long runtime.
You’ve got more than one? And use ’em for that? If you ever feel like parting ways with one, let me know
I recall discussion of the old Arc AAAs, which drop to moonlight when the battery’s near exhausted. Maker Gransee recommended that if anyone really needed the light to leave it on continuously rather than turning it off and back on later thinking to save the battery — because powering up the driver sucked so much power compared to just keeping the LED glowing.
yes but that moonlight is not an actual mode, its just the result of an exhausted battery. On a full battery, the Arc has no moonlight mode
I would rather get a light that produces a moonlight mode consistently, with a full battery too
Here’s the reddit post about the SC62w runtime test that was mentioned by several folks.
It passed one year a few days ago! It’s running an LG cell measured at 3425 mAh.
My SC62w has been in my pocket for 4 years now. The 0.01 lumen mode is indeed usable in some cases.
For fun, I just took these photos of three ZebraLights on their lowest modes.
From left to right is the SC62w, SC64c LE, and SC64c with a Nichia 219B sw45k swap.
The 219B is clearly the dimmest, followed by the SC62w at 0.01 lumens, then the SC64c LE at 0.05 lumens.
I am looking at long runtime with a usable amount of light. My Armytek Tiara sits at .4 lumen for an advertised 60 days. The Elf C2 advertises .4 lumen for 200 days. Nice.
I suppose, if in darkness long enough, .1 lumens could seem pretty bright. I guess the litmus test for me is the amount of light I would need to be able to read or navigate in the dark.
I would take any “measurements” of moonlight mode brightness with a grain of salt. It can vary a lot from one instance of a light to another.
Yes, most of the MkIV models have around a 0.07 lumen minimum. That’s been around for the past couple of years. Before that, they used to do 0.01 lumens.
Of my 4 most recent Zebralights (all MkIV versions), the SC600w HI, SC600w Plus, and SC64w HI, all have the 0.07 lumen minimum. My H600Fc has a lower minimum moonlight. It’s not quite as low as the old 0.01 outputs, but it’s nice to see they haven’t completely given up on the really low modes.
IMO, the 0.01 outputs are just too low to be useful. Perhaps usable to some, but not me. Great for run-time contests, though!
Heres a comparison of an SC64 LE (left) vs H600c MkIV (right)
“0.05lm” vs “0.08lm” respectively; this shows that it’s hard to get solid numbers with output this low.
I would hazard a guess that actual runtimes vs advertised runtimes are also something that can vary greatly as well? I am pretty new to a lot of this so I am trying to learn all I can.
I still have original box with 10.14.2014 written on it. It is my favorite EDC.
All I know is that it is an SC62,I think “D” version but not positive. 0.01 Lumens as others have mentioned.
You can see a scratch on the lens in this picture.
No it is not hard. Get yourself a 16 dollar luxmeter that reads as low as 0.1 lux, a 4 dollar styrofoam ball, a small piece of alu-tape and some cellotape to close the ball and fix the luxmeter. Two holes with an exacto knife later, and a basic calibration with a known output light, you have a measuring device that measures fairly accurate and repeatable down to 0.005 lumen, and a bit coarser down to 0.002 lumen.
I just received an AAA Manker E02 (Red body) that has a programmable moonlight level with a range of 19!!! different sublumen levels
this is the lowest, it is lower than any light I own except my magnetic rotaries
The above lumen values come from my own tests, I do not rely on mfg specifications.
the E02 actually reads ZERO on my meter (my meter’s lowest reading capability is 0.01, which means the E02 is making less than 0.005 lumens, due to rounding)
When researching a light, I use google image search, to look for reviews with independent output and runtime charts. I especially like reviews by zeroair, he is very thorough, but I did not find an E02 review on his site…
Thrunite Ti, firefly mode is 0.04 lumen…
that is a specification, but not actually correct, mine is actually 0.07 lumens minimum
I suggest you find an independent review, or use your own meter to measure.
It is also likely that not every light achieves the specification. That is the point BurningPlayd0h made in post 26 above, about his Zebras…
what the manufaturer specs say is not necessarily true, neither for output, nor for runtime
Trust, But Verify!
