The firmware called biscotti is just flashed into that driver, so same functionality, other current output.
The max output differs from the 17 mm and 22mm, the 22 standard delivers upto 6A, where the 17mm maxes out on 5A. Also a 6A might be available.
Playing with sense resistors might help allowing to change the max desired output current (up to 8A)
There were some C8+ on neals briefly with white flat 1 and I’d assume 5A driver - missed them, damn! Would be good to make one with either WF1 or WF2 (WF2 can handle more current IIRC, could do a resistor mod…)
It really depends what you’re looking after, a larger diameter head will give you a lot more throw, i have used a white flat in a C8 and placed it in a L21A later on, but the L21A gives a lot more throw with the same emitter (it is also driven harder now)
Question and suggestions (for Simon and/or anyone else).-
What are the actual (modder and tinkerer) differences between the classic 26650 L2 and the 21700 L21A? As far as I know, the L2 fits all 26650s, including the slightly wider, market leading Power Long Battery cells. However, I heard somewhere that the L21A has problems with some 21700 cells, i.e. the tube is too tight. If this is so, I would ask the machine shop to slightly widen the internal diameter of the L21A tubes (to ∅21.8 - 21.9 mm), modifying the drawings in the process, this way the L21A would be more appealing and trouble-free. Tip: Lishen cells are the widest I believe, at ∅21.7 mm with a single wrap, see just below:
Both fit ∅22 mm drivers with a little bit of filing, ∅21.5 - 21.6 mm driver bay. Don't know how deep is it but I guess very powerful buck or boost drivers can be used. 21700 extension tubes may appeal to someone.
Got this driver on c8+ and just swapped sst40 for flat white andforgot to apply the led gasket when screwing the reflector bit so might have shorted the driver… now led comes on and off only 0.01 % brightness or something you can only see if you look at it…
Anyone experienced this? Can you reset the driver after shorting the output?? I ordered one from big but don’t want to wait to test the c8 light sabre with flat white.
Thanks
The Convoy L2 won’t fit the Keeppower protected 6000mAh 26650, as per my test. Some 26650s are also tight (may fit when battery is pushed into the tube, but the battery won’t slide out when turning the tube upside down - so it’s that tight).
The Convoy L21A battery tube seems to suffer the same somewhat tight 21700 (it won’t fit the Sofirn 21700, Liitokala Lii-40A, nor iJoy 3750mAh 21700, as per my testing). Genuine Samsung 21700 and LG 21700 appears to fit.
